Python code to check geometry type
13241
09-14-2011 07:50 PM
philiptivel
I want to create an if else statement involving geometry types.
If geometry is a point run one process
elsif geometry is a line run different process.
Is there a way to do this using python?
HenryColgate
Layer below can be full path and shapefile or a feature layer etc.
desc = arcpy.Describe('C:/shapefile.shp')
geometryType = desc.shapeType
if geometryType == 'polygon':
    print 'Polygon'
elif geometryType == 'point'
philiptivel
Worked like a charm thanks!
StevenBowley1
Worked for me , but only after changing 'polygon' to 'Polygon' and 'point' to 'Point' (uppercase P) for some reason...
