Read an attribute field of a shapefile
5137
04-04-2012 10:35 AM
RaviSadasivuni1
I am a novice in python. Please help me.
I want to read an attribute field of a shapefile and print its attribute value in python.
The attribute is 'ATTRACTIVE'.
#My code:
# Import system modules
import sys, string, os, arcgisscripting
import arcpy
from arcpy import env
from arcpy.sa import *
# Create the Geoprocessor object
gp = arcgisscripting.create()
# Set current workspace
env.workspace = "H:\\desktop\\test"
# Read the attractive attribute
fieldList = arcpy.ListFields("H:\\desktop\\test\\testing0.shp")
'''for field in fieldList:
    field.name = "ATTRACTIVE" '''
DarrenWiens2
See the example for how to use a SearchCursor.
