pytframe used to build a database merger
1076
07-20-2024 06:29 PM
HaydenWelch
MVP Regular Contributor
#NOTE: I think this is in the wrong board and belongs more in Blog, but I don't have posting privileges there currently. I've seen some interest in this so I wanted it to be visible on this forum. I'll remove this if requested.
I've been developing a framework for rapid development and modularization of Python toolboxes and figured I'd share this example here:
import arcpy
from arcpy import Parameter
from utils.tool import Tool
from utils.models import Table, Workspace
import utils.archelp as archelp
from utils.archelp import print
class GDBMerger(Tool):
    def __init__(self):
        super().__init__()
        self.category = "Utilities"
        self.label = "GDB Merger"
        self.alias = self.label.replace(" ", "")
        self.description = "Merges multiple file geodatabases into a single file geodatabase."
        return
    def getParameterInfo(self) -> list[Parameter]:
        input_gdbs = Parameter(
            displayName="Input Geodatabases",
            name="input_gdbs",
            datatype="DEWorkspace",
            parameterType="Required",
            direction="Input",
            multiValue=True,
        target_gdb = Parameter(
            displayName="Target Geodatabase",
            name="target_gdb",
            direction="Input",
        # Do not attempt to merge any database that does not match the target schema
        strict_merge = Parameter(
            displayName="Strict Merge",
            name="strict_merge",
            datatype="GPBoolean",
            parameterType="Optional",
            direction="Input",
        strict_merge.value = False
        features_to_merge = Parameter(
            displayName="Features to Merge",
            name="features_to_merge",
            datatype="GPString",
            direction="Input",
            multiValue=True,
        features_to_merge.filter.type = "ValueList"
        tables_to_merge = Parameter(
            displayName="Tables to Merge",
            name="tables_to_merge",
            direction="Input",
            multiValue=True,
        tables_to_merge.filter.type = "ValueList"
        return [input_gdbs, target_gdb, features_to_merge, tables_to_merge, strict_merge]
    def updateParameters(self, parameters: list[Parameter]) -> None:
        params = archelp.Parameters(parameters)
        if params['target_gdb'].value and params['target_gdb'].altered:
            params['features_to_merge'].filter.list = [fc.split(r'\\')[-1] for fc in Workspace(params['target_gdb'].valueAsText).featureclasses]
            params['tables_to_merge'].filter.list = [tbl for tbl in Workspace(params['target_gdb'].valueAsText).tables]
        return
    def execute(self, parameters: list[Parameter], messages: list[object]) -> None:
        if not params["features_to_merge"].values and not params["tables_to_merge"].values:
            print("No features or tables selected to merge", severity="ERROR")
            return
        arcpy.SetProgressor("step", "Reading Target Schema", 0, 1, 1)
        features_to_merge = None
        tables_to_merge = None
        if params["features_to_merge"].values:
            features_to_merge: list[str] = [str(v).split('/')[-1] for v in params["features_to_merge"].values]
        if params["tables_to_merge"].values:
            tables_to_merge: list[str] = [str(v) for v in params["tables_to_merge"].values]
        input_gdbs: list[object] = params["input_gdbs"].values
        target_gdb: Workspace = Workspace(params["target_gdb"].valueAsText, featureclass_filter=features_to_merge, table_filter=tables_to_merge)
        strict_merge: bool = params["strict_merge"].value
        arcpy.ResetProgressor()
        for gdb_idx, input_gdb in enumerate(input_gdbs, start=1):
            arcpy.SetProgressor("step", "Reading Next Input Schema", gdb_idx, len(input_gdbs), 1)
            input_gdb = Workspace(arcpy.Describe(input_gdb).catalogPath, featureclass_filter=features_to_merge, table_filter=tables_to_merge)
            # Abide by strict merge rules on a per-geodatabase basis
            if not (target_gdb == input_gdb) and strict_merge:
                strict_merge_warning(input_gdb, target_gdb)
                continue
            print(f"Merging {input_gdb.name} into {target_gdb.name}")
            to_merge = input_gdb & target_gdb
            for tbl_idx, table in enumerate(to_merge, start=1):
                source: Table = input_gdb[table]
                target: Table = target_gdb[table]
                if len(source) == 0:
                    print(f"\t{source.name} has no rows to merge! ")
                    continue
                print(f"\t{source.name} {tbl_idx}/{len(to_merge)}: {len(source)} rows")
                # Abide by strict merge rules on a per-table basis
                if not source == target and strict_merge:
                    strict_merge_warning(source, target)
                    continue
                matching_fields = source & target
                # Append rows from source to target
                arcpy.SetProgressorLabel(f"Appending {source.name} to {target.name}")
                try:
                    merge_tables(source, target, matching_fields)
                except Exception as e:
                    print(f"\t\t{source.name} failed to merge: {e}", severity="ERROR")
                    continue
                print(f"\t\t{source.name} merged successfully  ({len(source)} rows)")
            arcpy.SetProgressorPosition()
        return
def merge_tables(source: Table, target: Table, matching_fields: list[str]):
    # Start an edit session on the target table
    with target.editor:
        # Get the target table's insert cursor
        with target.insert_cursor(matching_fields) as cursor:
            # Get the source table's search cursor
            with source.search_cursor(matching_fields) as rows:
                # Append each row from the source table to the target table
                for row_idx, row in enumerate(rows, start=1):
                    cursor.insertRow(row)
                    arcpy.SetProgressorLabel(f"Appending {source.name} to {target.name} ({row_idx}/{len(source)})")
    return
def strict_merge_warning(source: Table | Workspace, target: Table | Workspace):
    missing = target - source
    additional = source - target
    print(f"\t\t{source.name} does not match target schema", severity="WARNING")
    if missing:
        print(f"\t\t\tMissing from {source.name}:\n{missing}", severity="WARNING")
    if additional:
        print(f"\t\t\tAdditional in {source.name}:\n{additional}", severity="WARNING")
Interface Example
Messaging example
As you can see I was able to really simplify the actual meat of the tool. All the validation checks are handled by using overridden `| & ==` operators similar to python's internal set objects. This code will not work without the whole framework (available here as pytframe2) I've build some interfaces for FeatureClass and Workspace objects that allow a more natural interaction with them as objects in code and not a series of filepath strings that you move from function to function (see how the merge_table code is calling cursors on the objects themselves instead of on a filepath).
This technique is just a sideproject within the framework though. The goal of this framework is to make tool and toolboxes independent and allow for you to easily build helper modules in a maintainable way and get all the instant reload benefits of a flat PYT file.
HannesZiegler
Thank you for sharing your framework project with other users. It looks like it can be very useful for breaking up a python toolbox into separate modules and keeping them organized, and others will likely find it helpful too!
However, as you already noted in your post, since there is no specific request for new or improved features and functionality associated with this post, this is not the correct place to share this framework. Please see the ideas policy here.
This post is better suited for the Esri Community forum. Good places might be:
Thank you, we appreciate your willingness to share your knowledge, it can be extremely helpful for us and others.
