Programmatically activate traditional versioning of a feature class
1370
04-25-2025 03:11 AM
MattHowe
I have a fair number of feature classes in an enterprise geodatabase where I'd like to programmatically walk through each one and register it as versioned (traditional). As we're not using feature datasets, is the only way to do this manually or are there any ways to do it using arcpy for example?
AlfredBaldenweck
MVP Frequent Contributor
Yup! Register As Versioned (Data Management)—ArcGIS Pro | Documentation
The documentation is a little confusing because dataset doesn't always mean "Feature Dataset"; it can also mean feature class or table.
AlfredBaldenweck
TonyAlmeida
MVP Regular Contributor
Something basic,
mport arcpy
# Enterprise geodatabase connection
workspace = r"***/***/***/enterprise.gdb"
arcpy.env.workspace = workspace
# List all feature classes
feature_classes = arcpy.ListFeatureClasses()
# Loop through each feature class and register as versioned
for fc in feature_classes:
    try:
        full_path = os.path.join(arcpy.env.workspace, fc)
        print(f"Registering {fc} as versioned...")
        arcpy.RegisterAsVersioned_management(full_path, , "NO_EDITS_TO_BASE")
    except Exception as e:
        print(f"Failed to register {fc}: {e}")
for editing tracking maybe try, https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/enable-editor-tracking.htm
# Editor tracking configuration
created_user = "CREATED_BY"
created_date = "CREATED_DATE"
edited_user = "LAST_EDITED_BY"
edited_date = "LAST_EDITED_DATE"
fields = [f.name for f in arcpy.ListFields(full_fc)]
tracking_enabled = arcpy.Describe(full_fc).editorTrackingEnabled
if not tracking_enabled:
    arcpy.EnableEditorTracking_management(
        in_dataset=full_fc,
        creator_field=created_user,
        creation_date_field=created_date,
        last_editor_field=edited_user,
        last_edit_date_field=edited_date,
        add_fields="ADD_FIELDS",
        record_dates_in="UTC"
MattHowe
Thanks @TonyAlmeida . I'm ok with the code, it just wasn't clear as to whether it could be done at the feature class level as the documentation says feature dataset or table view. Thanks again!
