Problem with creating InsertCursor
7076
14
09-15-2014 11:50 PM
ChristofLink
I want to write a small tool, which insert some data into an MS-Access database (.mdb). But i have a problem to initialize the cursor.
The Code is very simple :
strOutputPath = r"I:\Data\Test.mdb\FS_BASEMAP\FCL_B_COVERSHEET_A"
icur = arcpy.InsertCursor(strOutputPath)
There is some more code but it stoped at this point and I get this error message:
  File "I:\Skript\AddFeatureSkript.py", line 70, in <module>
  File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\__init__.py", line 1214, in InsertCursor
    return gp.insertCursor(dataset, spatial_reference)
  File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\geoprocessing\_base.py", line 369, in insertCursor
    self._gp.InsertCursor(*gp_fixargs(args, True)))
RuntimeError: ERROR 999999: Fehler beim Ausführen der Funktion.
COM-Komponente der Objektklassenerweiterung konnte nicht erstellt werden. [FCL_B_COVERSHEET_A]
The error message is in german so I translate it:
ERROR 999999: Error when executing the function.
COM component object class extension could not be created. [FCL_B_COVERSHEET_A]
I don't know what the problem is, so hopefully some can help me.
Thanks, Regards
JoshuaBixby
MVP Esteemed Contributor
Do you have another machine to try it on?  Does this happen with all machines you are working on or just one?
ChristofLink
I have two other virtual maschines running on a server. One of them has ArcGIS v.10.2.2 installed, the other ArcGIS v 10.1.1 . I tried it on both maschines but this doesn't work either. The same error message...
JoshuaBixby
I was really thinking it might be something specific to that machine, but obviously that isn't the case.  I would say or suggest opening Support case, but best case scenario would be a bug that will be very low in terms of priority since it involves personal geodatabases.  This is where I would just find a workaround and say c'est la vie.
Good luck
ChristofLink
Ok thank you very much for your help.
I will open a Support case and if I got an solution I will post it here.
RandyKreuziger
Christof,
  Did you open a case and if you did is it a known bug?
