Intersection of arcpy polyline and polygon
3792
12-11-2014 05:37 AM
ChroAhmed
Hi everyone,
I'm trying to find intersection of two polylines with a set of polygons to determine the segment of each polyline that intersects with the polygons.
below is my sample code, I want to get the length of the polyline's segments that intersecte with the polygons but I continuously get one of the following error messages:
1-Eceptions.TypeError:Invalid geometry type for method- :    I get this error when I use (GEODESIC,PLANAR, GREAT_ELLIPTIC)as a type measurement in "getLength"method.
2- Access violation at address 5C5B11E8 in module 'GeometryXLib.dll'. Read of address 00000000:  I get this error when I use (PRESERVE_SHAPE) as a type measurment in "getLength"method.
I don't Know How to solve it. Any help and suggestion are greatly appreciated.
The Code is :
import arcpy
path="E:\Code_Python\Data_trial.gdb"
arcpy.env.workspace=path
infc="CandidateStations_clipped"
fc="PopulationDensity_poly_del"
OBJ_field="OBJECTID"
def get_station_shape(station_id):
    with arcpy.da.SearchCursor(infc,"shape@",'%s = %s'%(OBJ_field,station_id)) as cursor:
        t1=cursor.next()[0].lastPoint
    return t1
def get_population_shape(pop_stns):
    for i in range (len(pop_stns)):
        pop_list.append(get_station_shape(pop_stns))
    return pop_list
def determine_line_length(pop_list_line):
    pop_line=arcpy.Polyline(arcpy.Array([get_population_shape(pop_list_line)]))
    return pop_line
# Enter for loop for each feature
def get_polygon_shape(fc):
    pd_poly=[]
    for row in arcpy.da.SearchCursor(fc, ["OBJECTID", "SHAPE@"]):
        # Print the current multipoint's ID
        print("Feature {0}:".format(row[0]))
        partnum = 0
        # Step through each part of the feature
        for part in row[1]:
            # Print the part number
            print("Part {0}:".format(partnum))
            # Step through each vertex in the feature
            for pnt in part:
                poly=[]
                if pnt:
                    poly.append(pnt)
                    # Print x,y coordinates of current point
                    print("{0}, {1}".format(pnt.X, pnt.Y))
                else:
                    # If pnt is None, this represents an interior ring
                    print("Interior Ring:")
            tmp_poly=arcpy.Polygon(arcpy.Array(poly))
            pd_poly.append(tmp_poly)
            print tmp_poly
            partnum += 1
    print pd_poly
    return(tmp_poly)
pop_list_line=[[2,9],[1,7]]
for i in range(len(pop_list_line)):
    pop_list=[]
    pop_line=determine_line_length(pop_list_line)
    intersect=pop_line.intersect((get_polygon_shape(fc)),2)
    print intersect
    pop_list.append(intersect.getLength("GEODESIC"))
    print "pop_list=",pop_list
