Problem with AddJoin - "The Value Cannot Be A Table"
4713
11
04-26-2020 03:40 PM
Katie_Clark
MVP Regular Contributor
I am attempting to automate a process of exporting photos from a Survey123 geodatabase and give the output a custom filename, modified from the general script for exporting photos provided by Esri. Here is what I have so far. I am trying to join the Feature Layer, image_repeat table and image_repeat__ATTACH table before exporting the photos so that I can use fields that are in the feature class attribute table in the output file names.
import arcpy
from arcpy import da
import os
featureTable = arcpy.GetParameterAsText(0) # the Feature layer
repeatTable = arcpy.GetParameterAsText(1) # the image_repeat table
attachTable = arcpy.GetParameterAsText(2) # the image_repeat__ATTACH table
fileLocation = arcpy.GetParameterAsText(3) # Output folder location for the photos
arcpy.AddJoin_management(repeatTable, "parentglobalid", featureTable, "globalid")
arcpy.AddJoin_management(repeatTable, "Nutrient_Bank_Monitoring.globalid", attachTable, "REL_GLOBALID")
with da.SearchCursor(repeatTable, ['DATA', 'ATT_NAME', 'ATTACHMENTID', 'site', 'plot']) as cursor:
    for item in cursor:
        attachment = item[0] # blob data type
        site = str(item[3])
        plotNum = str(item[4])
        filenum = "ATT" + str(item[2]) + "_" # i.e. ATT531_
        filename = site + "_Plot" + plotNum + "_" + filenum + str(item[1]) #i.e. miyagi_creek_Plot6_ATT531_plot_image-20200324-143302.jpg
        open(fileLocation + os.sep + filename, 'wb').write(attachment.tobytes())
        del item
        del filenum
        del filename
        del attachment
However, I get the following error message - "The value cannot be a table":
I have no problem doing the joins manually in ArcMap, so I'm unclear why it won't work in the script. Is it possible to do what I'm trying to do?
I am obviously still a python newbie, so many thanks in advance for any help or advice!
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
MatthewWoodmansee
Thank you both David and Katherine for your help.  I am posting my final code (with commented-out manual data tests and print statements) in case this will help anyone else.  I added in an "If" statement for the user to chose a project number (there will be lots of different projects using this one Collector application). I also used a lot of the code from another thread (I had forgotten how helpful list comprehensions are!: Is it possible to use a field for the filename of an attachment export?
Here is my code - thanks again!
import arcpy
import os
inTable = arcpy.GetParameterAsText(0# attachment table name (_ATTACH)
fileLocation = arcpy.GetParameterAsText(1# folder of where the files will end up going
featureTable = arcpy.GetParameterAsText(2# feature class holding the data we need.
ProjectNum = arcpy.GetParameterAsText(3# project number user wants to export for
#featureTable = r"R:\Connections\GIS_Shared_Data.sde\GIS_shared_data.DBO.GlobalData_UTM\GIS_shared_data.DBO.AOC_testing"
featureFields = ['OBJECTID''ProjectNumber']
#use list comprehension to build a dictionary from SearchCursor
featureDict = {r[0]:(r[1:]) for r in arcpy.da.SearchCursor(featureTable, featureFields)}
#print featureDict
#related table, and the fields we want from that table
#inTable = r'R:\Connections\GIS_Shared_Data.sde\GIS_shared_data.DBO.AOC_testing__ATTACH'
TableFields = ['REL_OBJECTID''DATA''ATT_NAME']
#location of the folder where we place the attachments
#fileLocation = r'C:\Users\xxxxx\Desktop\TestingData\AttachmentTest'
#now run through the dictionary and create the files
with da.SearchCursor(inTable, TableFields) as cursor:
    for item in cursor:
        attachment = item[1]
        #item[0] is the unique ID (OBJECTID), take first item in Dictionary
        fileName1 = featureDict[item[0]][0]
        #print fileName1
        fileName2 = str(item[2]) #uses the "photo 1" text
        #print fileName2
        #add the ObjectID to the final version, then concat project number and attachment name
        fileNameFinal = str(item[0]) + "_" + str(fileName1) + "_" + fileName2
        #print fileNameFinal
        if fileName1 == ProjectNum:
            open(fileLocation + os.sep + fileNameFinal, 'wb').write(attachment.tobytes())
        del item
        del attachment
        del fileName1
        del fileName2
        del fileNameFinal
    del cursor
DavidPike
MVP Notable Contributor
You can reference the data via a cursor through the dataset path itself, not even sure if it works on a layer. Also save the layer after the join then use that path in the cursor.
for fields input into the cursor you can pass in a list of field names as strings:
cursor_fields = ["Field1", "Field2", "Field3"]
with arcpy.da.cursor(path, cursor_fields) as cursor...
throw some print statements into the variables you're creating in the cursor, my guess is your final path is ending up a bit funky after concatenation, i'd use os.path.join instead.
