Problem Deleting scratchGDB after script runs
14261
11
02-27-2014 05:22 AM
MarcCusumano
I have a script running that does a bit of spatial analysis, creates a relationship table and exports layout images to JPEG for report.
It runs great, but I am having a problem doing proper cleanup. I go to delete the scratchGDB using arcpy.delete, and it works fine. The problem is that a leftover scratch.gdb remains in the workspace directory.
After running arcpy.delete the leftover scratch.gdb is not a true geodatabase; in ArcCatalog it appears as a folder with a plus to the left of it. Drilling down on the plus and there is nothing in there.
I also added a line to delete that file in python and I get this:
[Error 5] Access is denied: 'D:\\gis\\Data\\scratch.gdb'
Sometimes the script works fine without deleting the scratch.gdb (it simply overwrites), other times it tells me it cannot create the initial output and fails. I would appreciate any help.
DanPatterson_Retired
hmmmm, I suspect it will stop when you reboot... never while something that you aren't sure is going to finish
PriscillaCole
"Did you try turning it off and on again?" -IT Crowd
I was also having this problem. arcpy.Delete_management(GDB_path) would not remove my GDB, and left a weird folder behind. I attempted the while-loop approach (mentioned above), but that turned out to be an infinite loop, and I had to kill ArcMap to stop it.  When I restarted ArcMap, the GDB hadn't been deleted. For fun, I tried running the original command again: arcpy.Delete_management(GDB_path). And it worked!
Restart to the rescue again!
