Printing the highest value between a range of values of a field
6963
11
06-11-2021 07:00 AM
Poncio
I'm completly new with python and wanted to do this little project that would be very useful. What I want to do in the end is having a little window pop up and showing the highest value of a field but only for a specific range of values, like between 1000 and 2000. Here's an example:
Field1
1001
1002
1003
2002
2005
3001
3003
3008
What I need in the end is a list like this (but for now I'd be happy to just print out the right values):
Zone1 = 1003
Zone2 = 2005
Zone3 = 3008
With advice and code from another place I managed to write this
import arcpy
fc = 'C:\..............\Einzelpunkt.shp'
fields = ['Identifika']
#setting up the max value variables
Zone1=0
Zone2=0
# For each row in the attribute table, use if statements
# to determine which category it is in and if it is bigger
# than the current max value for that category, update the
# max value variable
with arcpy.da.SearchCursor(fc, fields) as cursor:
for row in cursor:
if row[0]<20000 and row[0]>Zone1:
Zone1=row[0]
elif row[0]<30000 and row[0]>Zone2:
Zone2=row[0]
#keep adding elif statements to cover the rest of the Zones
#this will print out the last number used in the piano category
print "Zone1="+str(Zone1)
print "Zone2="+str(Zone2)
break
From what I can understand the if statements only take into account the first value in the column, wich in the example shape I have is ~31000 wich makes the statements false and not change the variables.
How should I approach this?
Keep in mind I'm a complete beginner 🙂
Poncio
Sorry, like last time, we got a lot of work and I kinda left this little project where it was and forgot about this...
In the meantime I found another solution tho: I use the modelbuilder to make what I was doing manually wich is to select by attribute for the zone and get the max value of the selected. After that I use a simple Python script to take the values and visualize them in a separate window. Now it's just a matter of cleaning up the modelbuilder (would need to make the number inside the select SQL a variable wich most likely requires to make it entirely in Python, I tried to convert the model but it's quite messy and definely out of my current competence). For now I'm happy since the result is usable.
DanPatterson
MVP Esteemed Contributor
divmod   oft forgotten
field1 = arcpy.da.TableToNumPyArray(...table to use..., ...field name...)
field1 = np.array([101, 102, 103, 202, 205, 301, 303, 308])  # input array
# --- classify, slice, group and solve
np.divmod(field1, 100)  # divisor is 100 in this case
q, r = np.divmod(field1, 100)  #  return the quotient and remainder
split_idx = np.nonzero(np.diff(q))[0]  #  return the indices where they differ
group_vals = np.array_split(r, split_idx+1)  # split the remainder into groups
#  ---- some results
q
array([1, 1, 1, 2, 2, 3, 3, 3], dtype=int32)  # quotient
r
array([1, 2, 3, 2, 5, 1, 3, 8], dtype=int32)  # remainder
split_idx
array([2, 4], dtype=int64)  # the indices for the group
group_vals  # the remainders in each group
[array([1, 2, 3], dtype=int32),
 array([2, 5], dtype=int32),
 array([1, 3, 8], dtype=int32)]
maxs = [g.max() for g in group_vals]  # get the max per group
maxs
[3, 5, 8]
Options abound, but divmod rarely gets show-cased.
... sort of retired...
