How to save a layer created from raster without using map document or ArcGISPro?
3051
08-16-2021 04:36 AM
RehanChaudhary
I have created a multidimensional raster layer using the "MakeMultidimensionalRasterLayer" tool  from arcgispro using the tool's python scripting and without using ArcGISPro and a map document. I created the layer as following:
p = arcpy.md.MakeMultidimensionalRasterLayer(in_multidimensional_raster=netCDF_in, out_multidimensional_raster_layer=temperature,variables=["tmin"])
Now i want to save this layer so that i can define a certain symbology to this layer file using the colorizer attribute within the file. I tried saving it using the following code but when i open the saved file in ArcGISPro, it crashes and the crash only happens because of the file otherwise its ok.
How can i achieve this?
lyr="temperature.lyr"
k=arcpy.SaveToLayerFile_management(p,lyr)
2 Solutions
DanPatterson
MVP Esteemed Contributor
you have to use the full path to the layer on disk.  That is
"c:/temp/temperature.lyr"   for arcmap
"c:/temp/temperature.lyrx"   for arcgis pro
... sort of retired...
DuncanHornby
MVP Notable Contributor
Geoprocessing tools return result objects so what you are assigning to "p" is a results object not a raster. You need to obtain the actual output using getOutput() on the result object. Review the code samples in the help file .
DanPatterson
DuncanHornby
