Preserve Editing Options when Overwriting Web Service with Python Script
1218
01-18-2022 08:43 AM
ckmcit4141
I have been working on implementing a Python script to automate overwriting web feature services hosted in ArcGIS Online each week.
I have setup a script that works well and I run it in ModelBuilder in ArcGIS Pro to update about 6 different services each week.
3 of the services that are overwritten each week need to have editing enabled for other users in the organization to be able to edit the services each week. Currently, when I overwrite these services, the editing parameters I have selected are reset (all editing disabled) when I overwrite the layers with my script. This requires me to have to log in to ArcGIS Online and reconfigure the editing parameters on each layer every week, which I would like to automate in my script.
To make matters more complicated, ArcGIS Online allows me to select which types of edits are allowed and I would like to be able to keep my settings. On 2 of the layers, I need to have only attribute updates allowed.
For example:
Enable Editing: True
What kind of editing is allowed?
Add: False
Delete: False
Update: True
Attributes Only: True
Attributes and Geometry: False
The 3rd feature service that I overwrite can allow all editing.
Is it possible to add these parameters to my overwrite script to automate the steps of configuring these settings? I will include the Python script I am using below. Thanks in advance!
import arcpy
import os, sys
from arcgis.gis import GIS
prjPath = r"C:\myfilepath\myprojectfile.aprx"
sd_fs_name = arcpy.GetParameterAsText(0) #Enter Feature Service Name in Script tool Parameter
portal = "http://www.arcgis.com" # Can also reference a local portal
user = "myusername"
password = "mypassword"
shrOrg = True
shrEveryone = False
shrGroups = ""
relPath = r"C:\myfilepath"
sddraft = os.path.join(relPath, "WebUpdate.sddraft")
sd = os.path.join(relPath, "WebUpdate.sd")
print("Creating SD file")
prj = arcpy.mp.ArcGISProject(prjPath)
mp = prj.listMaps()[0]
sharing_draft = mp.getWebLayerSharingDraft("HOSTING_SERVER", "FEATURE", sd_fs_name)
sharing_draft.summary = "My Summary"
sharing_draft.tags = "My Tags"
sharing_draft.description = "My Description"
sharing_draft.credits = "My Credits"
sharing_draft.useLimitations = "My Use Limitations"
sharing_draft.exportToSDDraft(sddraft)
arcpy.StageService_server(sddraft, sd)
print("Connecting to {}".format(portal))
gis = GIS(portal, user, password)
# Find the SD, update it, publish /w overwrite and set sharing and metadata
print("Search for original SD on portal…")
print(f"Query: {sd_fs_name}")
sdItem = gis.content.search(query=sd_fs_name, item_type="Service Definition")
i=0
while sdItem[i].title != sd_fs_name:
i += 1
print('Item Found')
print(f'item[i].title = {sdItem[i].title}, sd_fs_name = {sd_fs_name}')
item = sdItem[i]
item.update(data=sd)
print("Overwriting existing feature service…")
fs = item.publish(overwrite=True)
if shrOrg or shrEveryone or shrGroups:
print("Setting sharing options…")
fs.share(org=shrOrg, everyone=shrEveryone, groups=shrGroups)
print("Finished updating: {} – ID: {}".format(fs.title, fs.id))
