Polyline NumPy Array to Pandas DataFrame: StElevation and EndElevation?
14651
13
07-14-2017 02:21 AM
PeterWilson
I have converted a feature class (polylines) to a numpy array and have expoded the polylines to vertices using the "explode_to_points" method. I would like to convert the output numpy array to a pandas dataframe that will replicate the line segments that make up the polyline so that I land up with the following columns:
The table above was achieved by using "Split Line At Vertices". The fields "STElev" and "EndElev" are the Start Elevation and End Elevation of the line segments determined using "Calculate Geometry". The field "STElevation" and "EndElevation" is the change in elevation determined by subtracting the elevation from the first "STElev" which in this case is 355.8495.
The output numpy array from converting my feature class (polylines) and exploding the features to vertices is:
The values are:
[(DrainID, X, Y, Z)....] for each vertice
Created on 01 Jul 2017
@author: PeterW
# import modules and site-packages
import numpy as np
import pandas as pd
from pathlib import Path
import arcpy
# set environment settings
# check out extensions
arcpy.CheckOutExtension("3D")
def longestflowpath_3d(dtm, lfp_2d):
    """Generate LongestFlowPath 3D
    from LongestFlowPath 2D and DTM"""
    output_gdb = str(Path(lfp_2d).parents[0])
    lfp_3d = "{0}\\{1}".format(output_gdb, "lfp_3d")
    lfp_3d = arcpy.InterpolateShape_3d(dtm, lfp_2d, lfp_3d, vertices_only=True)
    arcpy.FlipLine_edit(lfp_3d)
    return lfp_3d
def area_under_profile(lfp_3d):
    """Determine the Equal Area Slope
    for each Drainage Area's Longest
    Flowpath"""
    arr = arcpy.da.FeatureClassToNumPyArray(lfp_3d, ["DrainID", "SHAPE@X", "SHAPE@Y", "SHAPE@Z"], explode_to_points=True)  # @UndefinedVariable
    print(arr)
def equal_area_slope(dtm, lfp_2d):
    Flowpath"""
    lfp_3d = longestflowpath_3d(dtm, lfp_2d)
if __name__ == "__main__":
    dtm = r"E:\Projects\2016\G113665\geoHydro\DTM2\raw1"
    lfp_2d = r"E:\Projects\2016\G113665\geoHydro\Model02\Results.gdb\LongestFlowPath_2D_Orig"
    equal_area_slope(dtm, lfp_2d)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
My current Python Module
How can I convert the current numpy array to a pandas dataframe that will restructure the vertices (DrainID, X, Y, Z) to (DrainID, STElevation (change in elevation), EndElevation (change in elevation), DistM (Length of segment)?
DanPatterson_Retired
Peter ...and from the world of numpy... can be greatly simplified if needed.  Values can be tied to segment lengths, but I will save that for a blog.
:polyline_demo.py
import numpy as np
import arcpy
ft = {'bool': lambda x: repr(x.astype('int32')),
      'float': '{: 0.2f}'.format}
np.set_printoptions(edgeitems=3, linewidth=80, precision=3,
                    suppress=True, threshold=100, formatter=ft)
def e_leng(a):
    """Length/distance between points in an array using einsum
    : details in one of my blogs... this can be simplified to 4 lines for 2D
    def cal(diff):
        """ magic happens for 1D, 2D, 3D and 4D arrays...
        d_arr = np.sqrt(np.einsum('ijk,ijk->ij', diff, diff))
        d_leng = d_arr.flatten()
        length = np.sum(d_leng)
        return length, d_leng
    diffs = []
    a = np.atleast_2d(a)
    if a.shape[0] == 1:
        return 0.0
    if a.ndim == 2:
        a = np.reshape(a, (1,) + a.shape)
    if a.ndim == 3:
        diff = a[:, 0:-1] - a[:, 1:]
        length, d_leng = cal(diff)
        diffs.append(d_leng)
    if a.ndim == 4:
        length = 0.0
        for i in range(a.shape[0]):
            diff = a[i][:, 0:-1] - a[i][:, 1:]
            leng, d_leng = cal(diff)
            length += leng
    return length, diffs
def report(subs):
    """print out the results"""
    for i in range(len(subs)):
        total, segs = e_leng(subs[i])
        frmt = """
        3D distances along polyline {}
        Segment distances
        Total = sum of segments ? {}
        print(frmt.format(total, segs, total == np.sum(segs)))
# ---- inputs ----
fc = r'C:\GIS\Geometry_projects\polyline_demo\polyline_demo.gdb\polylines'  # change
flds = ['OID@', 'SHAPE@X', 'SHAPE@Y', 'SHAPE@Z']  # these are horibble
SR = arcpy.Describe(fc).spatialreference
a = arcpy.da.FeatureClassToNumPyArray(fc,
                                      field_names=flds,
                                      spatial_reference=SR,
dt = [('ID', '<i4'), ('X', '<f8'), ('Y', '<f8'), ('Z', '<f8')]  # these are readable
a.dtype = dt                  # simplify the dtype
ids = np.unique(a['ID'])      # get the unique id values
p_lines = [a[a['ID'] == i] for i in ids]                 # collect polylines
subs = [np.c_[p['X'], p['Y'], p['Z']] for p in p_lines]  # stack coordinates
report(subs)  # print the results
Peter, did you finish this?
PeterWilson
Hi Dan
Unfortunately not yet, I started working through your code and got stuck in understanding your reasoning behind reshaping the array from two dimensional to three dimensional lines 31 to 36. I still have quiet a bit to learn about NumPy and haven't needed to work with anything more than a two dimensional array.
Peter, there is a caveat in that function which states ... this can be simplified to 4 lines for 2D ....
That is the full code when needing to determine lengths/distances in higher dimensions....
You need not worry about it unless you are working with 3D data (conventional X,Y,Z) or 4D data(3D shifted by a distance over time)
Plus the 'cal' function uses einsum which is a bit of an overkill to determine distance between points, for instance, that can be written much shorter if one is using polygons that one is normally going to encounter.  The methods that you will find on the forum will crawl when you are working with objects with millions of vertices (beyond the scope of ArcMap in any event).  I just like to use what works for the cases that I use.
Pythagorean theorem is good enough to determine 2D length if that is all you need.
