Optimizing a Script Using Python Cursors and Dictionaries
6619
14
05-03-2017 10:10 AM
TessOldemeyer
I am trying to update field in a feature class using attributes from other feature classes. For this, I am currently leveraging spatial joins on feature layers, search cursors, and update cursors. The script runs successfully on small datasets within a few minutes but chugs on large ones. It seems as though this would be a good candidate script to use Richard Fairhurst's /blogs/richard_fairhurst/2014/11/08/turbo-charging-data-manipulation-with-python-cursors-and-diction... technique. Though, I am still getting a grasp on how to best use dictionaries to optimize script performance and am unsure of where I can best use these techniques here. Any suggestions on how to boost the speed of this script? Maybe there is another option out there to optimize it? The script is using three feature classes, subLayer, transLayer, and ppLayer to update new fields in the subLayer feature class based on spatial and attribute relationships. I have attached and commented a simplified version of the code here. Some of the blocks are ran multiple time for different attributes, and I have stripped that out here to slim down the code.
Thanks in advance! Any advice will be hugely appreciated.
import arcpy
from arcpy import env
import time
start = time.time()
arcpy.env.OverwriteOutput = True
defaultGdbPath = 'C:\Topo_Check_V5.gdb'
subLayer='C:\Topo_Check_V5.gdb\Subs' #point feature class
transLayer='C:\Topo_Check_V5.gdb\TLS' # line feature class
ppLayer='C:\Topo_Check_V5.gdb\PPS' #point feature class
###### Line Counts: Count of connecting lines within distance of point feature class ################
#add in Line_Count field
arcpy.AddField_management(subLayer, "Line_Count", "SHORT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "")
TLineCountField = "Line_Count"
#MakeFeatureLayer
arcpy.MakeFeatureLayer_management(transLayer, "transLayer_lyr")
with arcpy.da.UpdateCursor (subLayer, [TLineCountField, "SHAPE@"]) as LineCountList:
    for subrow in LineCountList:
        arcpy.SelectLayerByLocation_management("transLayer_lyr", 'WITHIN_A_DISTANCE', subrow[1], .000002, "NEW_SELECTION")
        result=int(arcpy.GetCount_management("transLayer_lyr").getOutput(0))
        #print result
        subrow[0] = result
        LineCountList.updateRow(subrow)
print "Line_Count Updated"
del LineCountList
###### Line Counts 13.8 : Line counts based on attribute, repeated 9 more times for various attributes  ###########
#add in Line_Count_13_8 field
arcpy.AddField_management(subLayer, "Line_Count_13_8", "SHORT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "")
TLineCountField_13_8 = "Line_Count_13_8"
#VLTSField = "VLTS"
#Make feature layer
arcpy.MakeFeatureLayer_management(transLayer, "transLayer_13_8")
#where clause
where_13_8 = ' "VLTS" = 13.8 '
with arcpy.da.UpdateCursor (subLayer, [TLineCountField_13_8, "SHAPE@"]) as LineCountList_13_8:
    for subrow in LineCountList_13_8:
        arcpy.SelectLayerByLocation_management("transLayer_13_8", 'WITHIN_A_DISTANCE', subrow[1], .000002, "NEW_SELECTION")
        arcpy.SelectLayerByAttribute_management ("transLayer_13_8", "SUBSET_SELECTION", where_13_8)
        result=int(arcpy.GetCount_management("transLayer_13_8").getOutput(0))
        #print result
        subrow[0] = result
        LineCountList_13_8.updateRow(subrow)
print "Line_Count_13_8 Updated"
del LineCountList_13_8
############## *** repeat 'Line Counts' for all VLTSs ##########
############################## GU Count --count of interger field from ppLayer###############################
arcpy.AddField_management(subLayer, "GU_Count", "FLOAT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "")
GUCountField = "GU_Count"
#Make feature layer
arcpy.MakeFeatureLayer_management(ppLayer, "ppLayerGU")
#Make feature layer
arcpy.MakeFeatureLayer_management(transLayer, "transLayerGU")
pp_trans_GUJoin ='C:\Topo_Check_V5.gdb\pp_trans_GU_SpatialJoin'
SubLayer_pp_trans_GUJoin = 'C:\Topo_Check_V5.gdb\SubLayer_pp_trans_GUSpatialJoin'
#spatial join of feature layers
arcpy.SpatialJoin_analysis ("transLayerGU", "ppLayerGU", pp_trans_GUJoin, 'JOIN_ONE_TO_MANY', 'KEEP_ALL', '#', 'WITHIN_A_DISTANCE', .0005)
#add new count field for distinct count for PP count
arcpy.AddField_management(pp_trans_GUJoin, "Join_Count_PP", "LONG", "", "", "", "", "NULLABLE", "NON_REQUIRED", "")
#calculate field == Join_Count
arcpy.CalculateField_management (pp_trans_GUJoin, "Join_Count_PP", "!Join_Count!", "PYTHON_9.3")
#Make feature layer
arcpy.MakeFeatureLayer_management(subLayer, "SubLayer_Layer")
#Make feature layer
arcpy.MakeFeatureLayer_management(pp_trans_GUJoin, "pp_trans_GUJoin_Layer")
# create a list of fields to sum from pp_trans_GUJoin
fieldNamesToSum = ['Join_Count','GEN_UNITS', 'Join_Count_PP']
# create the field mapping object
fieldMappings = arcpy.FieldMappings()
# populate the field mapping object with the fields from both feature classes
fieldMappings.addTable("SubLayer_Layer")
fieldMappings.addTable("pp_trans_GUJoin_Layer")
# loop through the field names to sum
for Join_Count in fieldNamesToSum:
    # get the field map index of this field and get the field map
    fieldIndex = fieldMappings.findFieldMapIndex('Join_Count')
    fieldMap = fieldMappings.getFieldMap(fieldIndex)
    # update the field map with the new merge rule (by default the merge rule is 'First')
    fieldMap.mergeRule = 'Sum'
    # replace with the updated field map
    fieldMappings.replaceFieldMap(fieldIndex, fieldMap)
for GEN_UNITS in fieldNamesToSum:
    fieldIndex = fieldMappings.findFieldMapIndex('GEN_UNITS')
for Join_Count_PP in fieldNamesToSum:
    fieldIndex = fieldMappings.findFieldMapIndex('Join_Count_PP')
    fieldMap.mergeRule = 'Max'
arcpy.SpatialJoin_analysis ("SubLayer_Layer", "pp_trans_GUJoin_Layer", SubLayer_pp_trans_GUJoin, 'JOIN_ONE_TO_ONE', 'KEEP_ALL', fieldMappings, 'WITHIN_A_DISTANCE', .000002)
#Make feature layer
arcpy.MakeFeatureLayer_management(SubLayer_pp_trans_GUJoin, "JoinLayer")
with arcpy.da.UpdateCursor (subLayer, [GUCountField, "SHAPE@"]) as GUCalcCursor:
    for subrow in GUCalcCursor:
        arcpy.SelectLayerByLocation_management("JoinLayer", 'WITHIN_A_DISTANCE', subrow[1], .000002, "NEW_SELECTION")
        if int(arcpy.GetCount_management(in_rows="JoinLayer").getOutput(0))==1:
            with arcpy.da.SearchCursor("JoinLayer",['JOIN_COUNT','GEN_UNITS']) as JoinLayerCursor:
                for joinsubrow in JoinLayerCursor:
                    GEN_UNITS = joinsubrow[1]
                    PPTLINES = joinsubrow[0]
                if joinsubrow[1] > 0 and joinsubrow[0] > 0:
                    result = GEN_UNITS/PPTLINES
                else:
                    result = None
                #print result
                subrow[0] = result
                GUCalcCursor.updateRow(subrow)
####################### NULL or Zero Line Count ---Based off of 'Double' field in transLayer  ##################
#add in NULL_ZERO_LINE_COUNT field
arcpy.AddField_management(subLayer, "NULL_ZERO_LINE_COUNT", "SHORT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "")
FieldLineCountNULL_ZERO = "NULL_ZERO_LINE_COUNT"
#Make feature layer
arcpy.MakeFeatureLayer_management(transLayer, "transLayer_nullzero")
#where clause
NULL_ZERO_VLTS = ' "VLTS" is NULL or "VLTS" = 0  '
with arcpy.da.UpdateCursor (subLayer, [FieldLineCountNULL_ZERO, "SHAPE@"]) as NullZeroCountList:
    for subrow in NullZeroCountList:
        arcpy.SelectLayerByLocation_management("transLayer_nullzero", 'WITHIN_A_DISTANCE', subrow[1], .000002, "NEW_SELECTION")
        arcpy.SelectLayerByAttribute_management ("transLayer_nullzero", "SUBSET_SELECTION",NULL_ZERO_VLTS)
        result=int(arcpy.GetCount_management("transLayer_nullzero").getOutput(0))
        #print result
        subrow[0] = result
        NullZeroCountList.updateRow(subrow)
print "NULL_ZERO_LINE_COUNT Updated"
####################### PP LINE COUNT: from transLayer, ppLayer, subLayer spatial join  ##################
#add in PP_LINE_COUNT field
arcpy.AddField_management(subLayer, "PP_LINE_COUNT", "LONG", "", "", "", "", "NULLABLE", "NON_REQUIRED", "")
FieldPPCount = "PP_LINE_COUNT"
with arcpy.da.UpdateCursor (subLayer, [FieldPPCount, "SHAPE@"]) as ppLineCountList:
    for subrow in ppLineCountList:
        # JOIN_COUNT is sum of PPs joined to trans lines in the pp_trans_GUJoin spatial join
        with arcpy.da.SearchCursor("JoinLayer",['JOIN_COUNT']) as JoinLayerppLineCountCursor:
            for joinsubrow in JoinLayerppLineCountCursor:
                JOIN_COUNT = joinsubrow[0]
            result = JOIN_COUNT
            subrow[0] = result
            ppLineCountList.updateRow(subrow)
print "PP_LINE_COUNT Updated"
########################### PP_COUNT : from transLayer, ppLayer, subLayer spatial join ######################################
#add in PP_COUNT field
arcpy.AddField_management(subLayer, "PP_COUNT", "LONG", "", "", "", "", "NULLABLE", "NON_REQUIRED", "")
FieldPPCount = "PP_COUNT"
with arcpy.da.UpdateCursor (subLayer, [FieldPPCount, "SHAPE@"]) as ppCountList:
    for subrow in ppCountList:
        with arcpy.da.SearchCursor("JoinLayer",['JOIN_COUNT_PP']) as JoinLayerppCountCursor:
            for joinsubrow in JoinLayerppCountCursor:
                JOIN_COUNT_PP = joinsubrow[0]
            result = JOIN_COUNT_PP
            subrow[0] = result
            ppCountList.updateRow(subrow)
print "PP_COUNT Updated"
################################################# unique subs by VLTS - 13.8 : based off of transLayer attributes and transLayer,subLayer spatial join ########################
#add in UNIQUE_SUB_COUNT_13_8 field
arcpy.AddField_management(subLayer, "UNIQUE_SUB_COUNT_13_8", "SHORT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "")
UNIQUE_SUB_COUNT_13_8 = "UNIQUE_SUB_COUNT_13_8"
# Make feature layer
arcpy.MakeFeatureLayer_management(transLayer, "transLayer_uniquesubs")
#SUB1SUB2 = "SUB1SUB2"
arcpy.AddField_management("transLayer_uniquesubs", "SUB1SUB2", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "")
#SUB1SUB2_CalcField = ' "SUB_1" + ', ' + "SUB_2" + ', ' '
arcpy.CalculateField_management ("transLayer_uniquesubs", "SUB1SUB2", ' [SUB_1] + "," + [SUB_2] ')
#where clause
where_unique_13_8 = ' "VLTS" = 13.8 '
with arcpy.da.UpdateCursor (subLayer, [UNIQUE_SUB_COUNT_13_8, "SHAPE@"]) as UNIQUE_SUB_COUNT_13_8_List:
    for subrow in UNIQUE_SUB_COUNT_13_8_List:
        arcpy.SelectLayerByLocation_management("transLayer_uniquesubs", 'WITHIN_A_DISTANCE', subrow[1], .000002, "NEW_SELECTION")
        arcpy.SelectLayerByAttribute_management ("transLayer_uniquesubs", "SUBSET_SELECTION", where_unique_13_8)
        arcpy.DeleteIdentical_management("transLayer_uniquesubs", ['SUB1SUB2'])
        result=int(arcpy.GetCount_management("transLayer_uniquesubs").getOutput(0))
        #print result
        subrow[0] = result
        UNIQUE_SUB_COUNT_13_8_List.updateRow(subrow)
print "UNIQUE_SUB_COUNT_13_8 Updated"
##############repeat 'unique subs by VLTS' for all 9 VLTSs ##########
################################################# unique VLTS : based off of transLayer attributes and transLayer,subLayer spatial join  ########################
#add in UNIQUE_VLTS_COUNT field
arcpy.AddField_management(subLayer, "UNIQUE_VLTS_COUNT", "SHORT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "")
UNIQUE_VLTS_COUNT= "UNIQUE_VLTS_COUNT"
arcpy.MakeFeatureLayer_management(transLayer, "transLayer_uniqueVLTSs")
with arcpy.da.UpdateCursor (subLayer, [UNIQUE_VLTS_COUNT, "SHAPE@"]) as UNIQUE_VLTS_COUNT_List:
    for subrow in UNIQUE_VLTS_COUNT_List:
         arcpy.SelectLayerByLocation_management("transLayer_uniqueVLTSs", 'WITHIN_A_DISTANCE', subrow[1], .000002, "NEW_SELECTION")
         arcpy.DeleteIdentical_management("transLayer_uniqueVLTSs", ['VLTS'])
         result=int(arcpy.GetCount_management("transLayer_uniqueVLTSs").getOutput(0))
         #print result
         subrow[0] = result
         UNIQUE_VLTS_COUNT_List.updateRow(subrow)
print "UNIQUE_VLTS_COUNT Updated"
end = time.time()
print (end - start)/60
TessOldemeyer
I am currently getting an error on 'IDs' not being defined on line 3. Any suggestions for this? I am probably missing something completely obvious. Also, would there still be a performance benefit from creating the transLayer_lyr feature layer outside of the update cursor loop? I am looking to update the Line_Count field within the subLayer feature class vs. the subLayer_lyr, so maybe this negates the need for the subLayer_lyr? Thanks again!
MitchHolley1
IDs should be a list of all unique identifiers for the Trans_Lyr.
IDs = []
with arcpy.da.SearchCursor(transLyr, ['..A unique ID field..']) as cursor:
    for row in cursor:
        IDs.append(row[0])
del cursor
TessOldemeyer
Hmm, this seems to start but never finishes. I must be missing something. Thanks again for your help.
import arcpy
import time
start = time.time()
#TLineCountField = "Line_Count"
IDs = []
with arcpy.da.SearchCursor(transLayer, ['OBJECTID']) as cursor:
    for row in cursor:
        IDs.append(row[0])
with arcpy.da.UpdateCursor (subLayer, ["Line_Count"]) as LineCountList:
        for i in IDs:
            arcpy.MakeFeatureLayer_management(transLayer, "transLayer_lyr", """OBJECTID = %s""" %i)
            arcpy.SelectLayerByLocation_management("transLayer_lyr", 'WITHIN_A_DISTANCE', subLayer, .000002, "NEW_SELECTION")
            #print result
            subrow[0] = result
            arcpy.Delete_management("transLayer_lyr")
del LineCountList‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
del cursor
end = time.time()
print (end - start)/60‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
MitchHolley1
Move the print statement in line 34 to inside the for loop.  So move it to between line 33 and 34.  This will ensure that you're actually looping through the layer and updating rows.  Again, if you need a unique count for each line, this is going to take a while.  You may want to just do a Spatial Join.
TessOldemeyer
Thanks. Maybe going back to spatial joins will end up being more efficient. I was hoping to maybe optimize the cursor route. Thanks for bearing with me. I really appreciate the advice.
