Multi-line 'Body' in mime email
9386
09-17-2018 09:53 AM
JoeBorgione
New to using mime within a python email...
https://www.smallsurething.com/multi-line-strings-in-python/ :  this guy provides a couple of ways to create a multi-line string, but I can't seem to convince mime to use it in the body of an email.
body = """first line
        second line
        final line"""
print(body)
first line
        second line
        final line‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
# I use it in mime like this:
    msg = MIMEMultipart()
    msg["From"] = emailfrom
    msg["To"] = COMMASPACE.join(emailto)
    msg["Subject"] = "Please see attached xls for errors"
    body = """OriginObjectID & DestinationObjectID are the two lines in the error
            RuleDescription is what rule has been broken
            Name should be self-explanatory"""
    msg.attach(MIMEText(body,'plain'))
As shown in lines 6-8, this approach produces an indent that I'd like to avoid.
template = ("This is the first line.\n"
            "This is the second line.\n"
            "This is the third line.")
print(template)
This is the third line.‍‍‍‍‍‍‍‍‍
body = ("OriginObjectID & DestinationObjectID are the two lines in the error\n"
        "RuleDescription is what rule has been broken\n"
        "Name should be self-explanatory")
Is what I'd like to use, and it works great from the command line  but when I use it mime, the newlines are ignored so the body of my email is one long run-on sentence. What's the secret to get a nice looking, multi line mime-email body?
That should just about do it....
Tags (3)
MichaelVolz
Esteemed Contributor
Are you creating this in Pro's version of python?
If so, have you tried just using msg = EmailMessage() instead of msg = MIMEMultipart()?
JoeBorgione
No.... Just a stand alone script; the script itself runs some gp tools against an enterprise gdb to get topology errors.  After working that end, it creates an xls file of the errors that I attach to the email.  I just want the users to understand how to read the xls....
JoeBorgione
I imported the textwrap module as described here textwrap – Formatting text paragraphs - Python Module of the Week  and tweaked my 'body' variable a little bit:
import datetime,smtplib,textwrap,arcpy
body = """\nOriginObjectID & DestinationObjectID are the two lines in the error
\nRuleDescription is what rule has been broken
\nName should be self-explanatory"""
body = textwrap.dedent(body).strip()
and the email body looks like this:
and that works for me!
DanPatterson_Retired
explore textwrap a bit more... dedent, indent, wrap are a few of the gems that it contains. there are others
JoeBorgione
It seems to be a pretty cool find!
