Make PDF
4389
09-23-2015 11:41 PM
RajP
Hello,
I would like to make pdf from the polygon table. I would specific the current pdf with separate colour and neighbourhood would separate colour, Can any one suggest me?
DanPatterson_Retired
You have not indicated whethe you have  produced anything from the advice given here
create PDF for every polygon in the geodata.
which suggests... amongst other basic arcmap useage... that you examine data driven pages which will allow you to produce a large portion of what you want.
So since the first attempt was a bust... can you address the following if you wish to gain some help in attaining your goals...
  • Can you provide some working code or the steps that you took to try and produce the dataset manually ?
  • Or are you looking for a final finished product?
RajP
Thanks for your support. I got the solution for my Problem.
RebeccaStrauch__GISP
Raj, since my guess is you got your answer in the other thread, you may just want to delete this on since it is a duplicate of your other thread, or mark Dan's as correct since it points to the other.  That way this question won't be left open or shown as unanswered.​
