create PDF for every polygon in the geodata.
9259
15
09-19-2015 12:32 AM
RajP
I have the attribute table of Polygon. I would like to create Pdf for every polygon shape separately using Python Script. Can anyone suggest me?
GalAvraham
Hi Raj
There is a whole feature within the ArcGIS desktop for that purpose called Data Driven Pages - it is also supported with Arcpy tools for python scripting.
Data driven pages | ArcGIS Blog
Gal
RebeccaStrauch__GISP
To continue with Gal's suggestion, here is a link to the 10.3 help for the same Creating Data Driven Pages—Help | ArcGIS for Desktop
RajP
I would like to make pdf only one polygon in the Polygon attributes at a time.
DanPatterson_Retired
Should the previous, useful posts by Gal and Rebecca lack the result you had anticipated...I shall be more direct:
Show us the code that you have attempted from the reading in the links provided
The discussion can continue from that point.
RajP
This is the image.  I have to update the SNO, Chalta_No, and Village filed as "Survy no", "ChalataNo" and Village in the layout view automatically. Can you suggest me?
The Data Driven Pages should be able to do all that.​ Using dynamic text with Data Driven Pages—Help | ArcGIS for Desktop   explains how to use it for dynamic text elements.
Raj...you may also want to look at this discussion
Data Driven Pages in ArcGIS Pro (Customization)
Jennifer McCall​ includes a script that may help with what you are trying to do.
RajP
Is it possible can we calculate length of line in the polygon feature class.
RajP
I would like to print the length of polygon in the layout view.
