looping after the last item in UpdadateCursor is very slow
1391
10-12-2022 06:08 AM
oferszekely
Hi!
I'm trying to add  the polygons of lines that applied certain criteria to the last row and delete all the row beside the last one.
The problem is that it is very slow.
When I run debugger  it turns out that "for row in cursor:" is stuck for a long time after finishing the last item.
I mean, the line "cursor.updateRow(row)" is executed only in the last item. after that the debugger goes back
to the line "for row in cursor:" and stays there for a few minutes.
Why is this happens?
with arcpy.da.UpdateCursor(my_layer, field_names, '"SETTLEMENT" = ' + str(x) ) as cursor:
    numberOfLinesLeft = sum(1 for row in cursor)
    cursor.reset()
    flag=0
    for row in cursor:
        if flag==0:
            temp_shape = row[0]
            flag=1
        else:
            temp_shape = temp_shape.union(row[0])
        if numberOfLinesLeft > 1:
            cursor.deleteRow()
            numberOfLinesLeft -=1
        else: # We reached the last row, In this row we need to update it's shape
            row[0]=temp_shape
Tags (1)
Kara_Shindle
Can you repost with it inserted in the Code window so we can see the indents?
I don't know if deleting the cursor on your last line will help?
oferszekely
Yes.
I also want to mention that I'm using Python 2.7.8
        counter = sum(1 for row in cursor)
        cursor.reset()
        flag=0
        for row in cursor:
            if flag==0:
                temp_shape = row[0]
                flag=1
            else:
            if counter > 1:
                cursor.deleteRow()
                counter -=1
                row[0]=temp_shape
by Anonymous User
Not applicable
This looks like you are trying to do a dissolve operation?
Maybe revising the process to use the dissolve.htm tool will work better?
