Loop through and run models in a toolbox
1625
12-08-2023 12:31 PM
sk08
Is it possible to loop through all models in a custom toolbox and run them instead of having to list them individually in the script?
Here is my script.
import arcpy
# Import custom toolbox
tbx = arcpy.ImportToolbox("E:\HostedFeatureLayers\Stormwater\Stormwater\Default.atbx")
try:
tbx.UpdateswInlet()
print("Finished Append: swInlet")
tbx.UpdateswManhole()
print("Finished Append: swManhole")
tbx.UpdateswDischargePoint()
print("Finished Append: swDischargePoint")
tbx.UpdateswWeirStructure()
print("Finished Append: swWeirStructure")
tbx.UpdateswOpenDrain()
print("Finished Append: swOpenDrain")
tbx.UpdateswPipe()
print("Finished Append: swPipe")
tbx.UpdateswDetention()
print("Finished Append: swDetention")
except arcpy.ExecuteError:
print(arcpy.GetMessages(2))
DanPatterson
MVP Esteemed Contributor
for line numbers and proper formatting
Code formatting ... the Community Version - Esri Community
Now, what happened when you ran it?
You could also have a look at
ListTools—ArcGIS Pro | Documentation
to see if you can run them that way
... sort of retired...
sk08
The above script worked fine (the formatting didn't come through when I copied it into here).
This is another version I had tried that did not work:
import arcpy
tbx = arcpy.AddToolbox("E:\HostedFeatureLayers\Stormwater\Stormwater\Default.atbx")
tools = arcpy.ListTools("*_Defaultatbx")
for t in tools:
  try:
    arcpy.t()
    print(t)
AttributeError                            Traceback (most recent call last)
In  [3]:
Line 9:     arcpy.t()
AttributeError: module 'arcpy' has no attribute 't'
AlfredBaldenweck
MVP Frequent Contributor
Try ListTools—ArcGIS Pro | Documentation ?
Something like this, I think
tbx = arcpy.AddToolbox()
for tool in arcpy.ListTools(tbx):
    tbx.tool()
DanPatterson
You just can't 'arcpy.t ' it.  Here is a command line example for one of my toolboxes
tbx = arcpy.AddToolbox(r"C:\arcpro_npg\npGeom_32.atbx")
nme = tbx.__name__
nme
'npgtools'
tools = arcpy.ListTools("*_npgtools")
arcpy.Usage(tools[0])
'AttributeSort_npgtools({Tool}, Input_features, Sort_fields;Sort_fields..., {Output_field})'
arcpy.AttributeSort_npgtools( ..... # now what do you see here for your toolset?
