Load data (shp and features) out of multiple folders and subfolders in one FGDB
1366
08-08-2016 06:50 AM
JohannesBierer
## Load Data
import arcpy
import os
workspace = r"R:\Daten\geo_daten_Kopie"
out_workspace = r"R:\Karto\Bierer2016\OrdnerRDatenGeodatenBereinigen\SIC_Geodaten.gdb\data"
import arcpy
import os
feature_classes = []
for dirpath, dirnames, filenames in arcpy.da.Walk(workspace, datatype="FeatureClass"): ##, type="Polygon"):
    for filename in filenames:
        feature_classes.append(os.path.join(dirpath, filename))
        name = os.path.join(dirpath, filename)
        print name
        BaseName = os.path.basename(name)
        print BaseName
        BaseNameCopy = BaseName.split(".shp")
        print BaseNameCopy
        arcpy.CopyFeatures_management(filename, os.path.join(out_workspace, BaseNameCopy))
The code leads to this error message:
  File "H:/python_scripte/ListFolderandShapes/ListFeatures_FoldersSubfolders_CopyFeatures_3.py", line 22, in <module>
  File "C:\Python27\ArcGIS10.2\lib\ntpath.py", line 73, in join
    elif isabs(b):
  File "C:\Python27\ArcGIS10.2\lib\ntpath.py", line 58, in isabs
    return s != '' and s[:1] in '/\\'
TypeError: 'in <string>' requires string as left operand, not list
Anyone has got an idea for a better solution?
FC_Basson
Like I said before, your output basename created after the split creates a list, so you need to access the first item of the list and not the entire list:
print BaseNameCopy[0]
arcpy.CopyFeatures_management(filename, os.path.join(out_workspace, BaseNameCopy[0]))
FC_Basson
JakeSkinner
Esri Esteemed Contributor
Hi Johannes,
To add onto FC's response, also remove 'data' from your out_workspace so that this is simply referencing a file geodatabase.
out_workspace = r"R:\Karto\Bierer2016\OrdnerRDatenGeodatenBereinigen\SIC_Geodaten.gdb"
