ListLayers error
8163
13
02-09-2015 10:13 AM
DEAF_PROBERT_68
Honored Contributor
I am having an syntax error from Pyscripter here and not sure why but I have a shapefile at the top of the TOC list which is the first and should be number zero  when writing a listlayers as a zero  but I still get the error .
The error is :
  File "C:\Student\python\GeoTIFF.py", line 16, in <module>
    gridlayer = arcpy.mapping.ListLayers(mxd,'JERGRIDINDEX', df,)[0]
IndexError: list index out of range
Take a look here the sytanx:: gridlayer = arcpy.mapping.ListLayers(mxd,'JERGRIDINDEX', df,)[0]
JakeSkinner
Esri Esteemed Contributor
Hi Robert,
Would you be able to post all of your code?  This will help troubleshoot this faster.
DEAF_PROBERT_68
Honored Contributor
Here you go:
mport arcpy.mapping, os
mxd = arcpy.mapping.MapDocument (r"E:\workspace\Test.mxd")
arcpy.env.workspace = r"E:/workspace/images/"
df = arcpy.mapping.ListDataFrames(mxd)[0]
df.scale = 40000
arcpy.SelectLayerByAttribute_management(gridlayer, "NEW_SELECTION")
for row in arcpy.SearchCursor(gridlayer):
  df.panToExtent(row.shape.extent)
  arcpy.RefreshActiveView()
  filename = "E:/workspace/images/" + \
    str(row.getValue("PageNumber")).zfill(4) + ".tif"
  arcpy.mapping.ExportToTIFF(mxd, filename, df, df_export_width= 65000, df_export_height=30000,geoTIFF_tags=True)
##  arcpy.mapping.ExportToTIFF(mxd, filename, df, df_export_width= 1280, \
##    df_export_height=440, geoTIFF_tags=True)
print arcpy.GetMessages()
JakeSkinner
Everything looks correct, unless you are mis-spelling the layer name.  However, since you want the first layer, you will not have to specify a name.  Try the following:
gridlayer = arcpy.mapping.ListLayers(mxd,'', df,)[0]
One thing I did just notice is the arcpy.env.workspace.  Since you are specifying an 'r' before the path, you will want to change the forward slashes to backslashes.  Ex:
arcpy.env.workspace = r"E:\workspace\images"
DEAF_PROBERT_68
Honored Contributor
I did the same thing what you suggest. I can try and run it from Python window but Pyscripter should be able to recongize it.  Can I run this script from Pyscripter rather than in python window ?
JakeSkinner
Yes, you should be able to run this in Pyscripter.
DEAF_PROBERT_68
Honored Contributor
How can I sync this Pyscripter to Arcmap ?
JakeSkinner
I'm not quite sure what you mean.  When the code is executed in Pyscripter, you will not see the map's extent updated.  However, you should still have the TIFF file created.
DEAF_PROBERT_68
Honored Contributor
I am thinking maybe it is not working.How can Pyscripter communicate with ArcMap if I write these codes ?
GusMartinka
Check out the Execute and debug your tool section for help attaching pyscripter to ArcMap for debugging.
