ListFields Not Working for Feature Classes in Enterprise SDE
3088
05-11-2021 12:25 PM
EvanMyers1
I have been running into a strange issue with a code I am working on and it only happens when I am working with data formatted like this.  This is from a script that uses a Multivalued Parameter. See below:
fc = "'Database Connections\\[email protected]\\Prod.Water\\Prod.ControlValve';'Database Connections\\[email protected]\\Prod.Water\\Prod.wFitting';'Database Connections\\[email protected]\\Prod.Water\\Prod.wHydrant'"
fclist = fc.split(";")
for each in fclist:
    fieldnames = [f.name for f in arcpy.ListFields(each)]
    print fieldnames
From this I get the error:
Runtime error
File "<string>", line 2, in <module>
File "c:\program files (x86)\arcgis\desktop10.7\arcpy\arcpy\__init__.py", line 1139, in ListFields
return gp.listFields(dataset, wild_card, field_type)
File "c:\program files (x86)\arcgis\desktop10.7\arcpy\arcpy\geoprocessing\_base.py", line 346, in listFields
self._gp.ListFields(*gp_fixargs(args, True)))
IOError: "'Database Connections\[email protected]\Prod.Water\Prod.ControlValve'" does not exist
I am at a loss with this error as it appears quite often.  If anyone has any points how to avoid this error I would be extremely grateful!
EvanMyers1
It turns out it was the single quotes ( ' ) around each file path that was giving me issues.  Never knew those would prevent arcpy.Describe and arcpy.ListFields from working 😵
PhilLarkin1
You could use arcpy.describe and .exists to validate the connection file is valid.
DavidPike
MVP Notable Contributor
maybe some raw formatting on the strings
fc = "r'Database Connections\\[email protected]\\Prod.Water\\Prod.ControlValve';r'Database Connections\\[email protected]\\Prod.Water\\Prod.wFitting';r'Database Connections\\[email protected]\\Prod.Water\\Prod.wHydrant'"
for each in fclist:
    print (each)
    print fieldnames
DanPatterson
MVP Esteemed Contributor
Beyond not using paths that contain spaces, and punctuation (which can cause inconsistent issues).
Set your works space and after parsing the featureclass/feature/table names, do a final check to see if it "exists"
arcpy.env.workspace = "c:/your_path/your.gdb"
# ------ does it exists
if arcpy.Exists("your_fc"):
    Do stuff
... sort of retired...
EvanMyers1
