Labels not display in pdf
1902
11-12-2014 02:49 AM
H_A_D_Padmasiri
Dear Sir!
     I tried to write a python script to display labels, and export to pdf. But in pdf the labels are not display.
My script is given below. Pl give me a advice to correct it.
import arcpy
from arcpy import mapping
mxd = arcpy.mapping.MapDocument(r"J:\Gampaha\51027202\ASD.mxd")
df = arcpy.mapping.ListDataFrames(mxd, "*")[0]
LayerFile = arcpy.mapping.Layer(r"J:\Gampaha\51027202\LIS.lyr")
arcpy.mapping.AddLayer(df, LayerFile, "AUTO_ARRANGE")
df.zoomToSelectedFeatures()
ExistLayer = arcpy.mapping.ListLayers(mxd, "*", df)
if ExistLayer[0].supports("LABELCLASSES"):
  List1 = ExistLayer[0].labelClasses
  List1[0].className = "Parcelid"
  List1[0].expression = "[Parcelid]"
  List1[0].showClassLabels = True
mxd.saveACopy(r"J:\Gampaha\51027202\Pro.mxd")
arcpy.mapping.ExportToPDF(mxd, r"J:\Gampaha\51027202\Pro.pdf")
del mxd
Thanks
Padmasiri
DanPatterson_Retired
You don't indicate if it does support label classes
if lyr.supports("LABELCLASSES"😞
    print "supports label classes"
else:
    print " a big no to that"
