iterating rasters to input into weighted overlay
2394
7
10-16-2014 01:37 PM
AmyKlug
I am preforming a weighted overlay. All of my raster's are in 1 folder. There are 4 different rasters that will be used in the weighted model (s,v,o,l)
1 run through will use 4 raster's with 0520a as the example code (I have 75 or so codes of rasters in 1 folder)
s0520a
v0520a
o0520a
l0520a
I need to find a way to select a code and loop through each 5 digit code code and add the s,v,o,l to the model then move on to the next code. If this was using a search cursor I would just set for r[0] but I'm not sure how to do that for looping through rasters. Also not sure how to create the output raster (send the code variable to the output name I suppose)
Thanks in advance!
Here is what I have so far:
import arcpy
arcpy.CheckOutExtension("spatial")
arcpy.overwriteOutput = True
inrcras = "C:\\Risk2014\\TestReclass\\"
arcpy.env.workspace = "C:\\Risk2014\\TestReclass"
rcras = sorted(arcpy.ListRasters())
outras = "C:\\Risk2014\\TestWeighted\\w"
for r in rcras:
    print r[4:] #code isolated for iterating
    if r[1] == "s":
        s = inrcras + r
    if r[1] == "v":
        v = inrcras + r
    if r[1] == "o":
        o = inrcras + r
    if r[1] == "l":
        l = inrcras + r
    print s, v, o, l
    #arcpy.gp.WeightedOverlay_sa("(s 25 VALUE (1 1; 2 2; 3 3; 4 4; 5 5; 6 6; 7 7; 8 8; 9 9; NODATA NODATA); v 25 VALUE (1 1; 2 2; 3 3; 4 4; 5 5; 6 6; 7 7; 8 8; 9 9; NODATA NODATA); o 25 VALUE (1 1; 2 2; 3 3; 4 4; 5 5; 6 6; 7 7; 8 8; 9 9; NODATA NODATA); l 25 VALUE (1 1; 2 2; 3 3; 4 4; 5 5; 6 6; 7 7; 8 8; 9 9; NODATA NODATA));1 9 1", outras + ?)
del r, rcras
DanPatterson_Retired
Amy is this the kind of thing you are looking for?  I put in a set of fake rasters...I hope your sorting idea works since this is a bit of a cludge approach
l: C:\Risk2014\TestReclass\Dliu0Test
o: C:\Risk2014\TestReclass\Doiu0Test
v: C:\Risk2014\TestReclass\Dviu0Test
s: C:\Risk2014\TestReclass\Dsiu0Test
Weighted: C:\Risk2014\TestWeighted\w0Test
l: C:\Risk2014\TestReclass\rliu0520a
o: C:\Risk2014\TestReclass\roiu0520a
v: C:\Risk2014\TestReclass\rviu0520a
s: C:\Risk2014\TestReclass\rsiu0520a
Weighted: C:\Risk2014\TestWeighted\w0520a
import arcpy
reclass_path = "C:\\Risk2014\\TestReclass\\"
# change to arcpy.ListRasters() I put in a few fake ones
raster_list = sorted(['rsiu0520a','rviu0520a','roiu0520a','rliu0520a',
                      'Dsiu0Test','Dviu0Test','Doiu0Test','Dliu0Test'])
print raster_list
count = 0
for raster in raster_list:
  code = raster[-5:]
  val = raster[1]
  if val == "l":  l = reclass_path + raster
  elif val == "o":  o = reclass_path + raster
  elif val == "v":  v = reclass_path + raster
  elif val == "s":  s = reclass_path + raster
  count += 1
  if count > 3:
    #arcpy weighted overlay magicmagic
    out_ras ="C:\\Risk2014\\TestWeighted\\w" + code
    print("\n l: {0}\n o: {1}\n v: {2}\n s: {3}\n Weighted: {4}".format(l,o,v,s,out_ras))
    count = 0
is your indexing off?  I think you want to get the 1st character (?), if so it is index 0
>>> r = 's0520a'
>>> r[4:]
'0a'
>>> r[1]
'0'
>>> r[0]
's'
AmyKlug
No, my rasters are really named
rsiu0520a
rviu0520a
roiu0520a
rliu0520a
i shortened them to make it easier to understand but didn't think to change the code, my bad
could you edit or restate your question so that we are now clear what you are asking
AmyKlug
I have 4 rasters for each code that need to go in to a wieghted overlay, each wieghted 25%. The code is the last 5 characters of the raster name and the 4 rasters are distinguished by s, v, o and l
Example
Code 0520a has 4 rasters
rsiu0520a
rviu0520a
roiu0520a
rliu0520a
In 1 folder are 75 codes each with 4 rasters so i need to grab the code, then each raster for that code, load them into weighted overlay, save output as code name with a w in the name (w0520a), and move on to the next code
Hope that makes sense
import arcpy
print raster_list
count = 0
  code = raster[-5:]
  val = raster[1]
  count += 1
  if count > 3:
    count = 0
AmyKlug
Thanks, That helped a lot (I still need to get the count thing down). I had to change the raster names to iu0520arc so they would sort. I would still like to find a way to select (set) for one code (and not need to sort) for times when a raster for a code might be missing but the only way I know how to do that is with a search cursor in a table and create dictionary's.
import arcpy
from arcpy.sa import *
raster_list = sorted(arcpy.ListRasters())
#outras = "C:\\Risk2014\\TestWeighted\\w"
#for raster in raster_list:
    #front, back = raster[2:], raster[:2]
    #print front, back
    #arcpy.Rename_management(raster, front + back)
#del raster
count = 0
    code, val =  raster[2:7], raster[8]
    #print code, val
    if val == "s":
    if val == "v":
    if val == "o":
    if val == "l":
    count += 1
    if count > 3:
        out_ras = "C:\\Risk2014\\TestWeighted\\w" + code
        remap = RemapValue([[1,1], [2,2], [3,3], [4,4], [5,5], [6,6], [7,7], [8,8], [9,9], ["NODATA","NODATA"]])
        mwt = WOTable([[str(s), 25, "VALUE", remap],[str(v), 25, "VALUE", remap],[str(o), 25, "VALUE", remap],[str(l), 25, "VALUE", remap]],[1,9,1])
        out_overlay = WeightedOverlay(mwt)
        out_overlay.save(out_ras)
        count = 0
del raster, raster_list
Glad it worked out Amy
