Iterate Elevation Source in Arcpy
980
02-05-2023 02:14 PM
AnonymousUser23
Looking for help on how to access and iterate switching out elevation sources in a scene in Arcgis pro through arcpy. I see that the "elevation source" is not in the listLayers() and I cannot find any calls to access any part of Elevation Surfaces. Hoping someone has done this.
Tags (3)
DuncanHornby
MVP Notable Contributor
Just an idea, if you cannot remove the layers how about building up new scenes and adding the elevation sources? Don't know if that is possible as I have used a scene in arcpy. You may have to explore using the CIM module?
