Issues with update cursor in Python
6471
7
02-02-2015 11:44 AM
BrianTweedle
Hi all, I am new to Python and I am currently working on a project where I am attempting to use the update cursor to use a numeric value in a field, and populate a secondary field with text values based off of those numeric values. This code will run successfully, but it will not update the field as desired. My e.message is giving me an __exit__  message. Here is my code:
# Import system modules
import arcpy
from arcpy import env
# Set environment settings
env.workspace = "F:\Geog390\Lab 3\Lab3.gdb"
env.overwriteOutput = True
fc = 'TPSJ'
fields = ('Join_Count', 'Validate')
#'TPSJ' is my feature class, 'Join_Count' is my first field, and 'Validate' is the field I am trying to populate
try:
    with arcpy.UpdateCursor(fc,fields) as cursor:
          for row in cursor:
               if row.getValue[JOIN_COUNT] == 1:
                   row.setValue[VALIDATE] = "Validated"
               else:
                   row.setValue[VALIDATE] = "Not Validated"
    cursor.updateRow(row)
except Exception, e:
    print e.message
any help would be greatly appreciated, thanks!
OwenEarley
Its hard to tell from the pasted code but you may have a code indentation issue on the updateRow() line.
import arcpy
fc = "c:/data/base.gdb/roads"
field1 = "field1"
field2 = "field2"
cursor = arcpy.UpdateCursor(fc)
for row in cursor:
  # field2 will be equal to field1 multiplied by 3.0
  row.setValue(field2, row.getValue(field1) * 3.0)
Note in this sample how the cursor.updateRow(row) line is nested within the for row in cursor loop.
DarrenWiens2
If you want to update for each row, place cursor.updateRow(row) at the same indentation level as the if/else.
OwenEarley
import arcpy
field1 = "field1"
field2 = "field2"
for row in cursor:
HunterWest
The aforementioned updateRow indentation error is probably the most likely fix, however, I would mess around with the format of your "field" definition as well.
Currently you have your fields formatted as a tuple rather than a list. I've never used tuples for cursor field lists (so I don't know how well they work or not), but I do know that the "fields" category in cursors can be touchy with regards to formatting.
I would try this instead and see if it works:
fields = 'Join_Count; Validate'
Good luck
BrianTweedle
I decided to forego the try/except statements and I just used the for loop. My main issue was in fact the indentation of my updateRow() line. I have successfully completed this using this code:
import arcpy
cur = arcpy.UpdateCursor("TP_SJ2")
for row in cur:
    if row.JOIN_COUNT == 1:
        row.VALIDATE = "Validated"
    else:
        row.VALIDATE = "Not Validated"
        cur.updateRow(row)
    del row
del cur
Thanks all for the help!
OwenEarley
Just a quick note - your updateRow will not be called for 'Validated' rows unless you drop the indentation back one level:
import arcpy
for row in cur:
    else:
        cur.updateRow(row) # < this will not be called for 'Validated' rows
    del row
del cur
Final version should be:
import arcpy
for row in cur:
    else:
    cur.updateRow(row)
    del row
del cur
BrianTweedle
Ah yes, thank you as it was only updating what was in my else statement.
RogerDunnGIS
This is neat.  I've never seen cursors used that way before.  I always thought that row was a tuple, so I always access it by index.  I've never used the dot notation to access fields before and never knew they had methods like setValue.  What I've been doing is declaring a list of fields I want in the cursor and assigning that to a variable.  Then in the loop I'll write something like row[lstFields.index("MYFIELD")] = someValue.  Thanks for sharing!
