Is layer in grouplayer
2495
06-08-2011 12:58 AM
HenkZwols
Hello all,
Is there a way in Python/Arcpy to find out if a featurelayer is in a grouplayer?
Greetings, Henk
AndrewChapkowski
There is a layer property called isGroupLayer which returns a boolean value (true/false).
    path = r"C:\temp\ds.mxd"
    mxd = arcpy.mapping.MapDocument(path)
    df = arcpy.mapping.ListDataFrames(mxd)
    for frame in df:
        for layer in arcpy.mapping.ListLayers(mxd, "*",frame):
            print layer.name
            print "isFeatureLayer - " + str(layer.isFeatureLayer)
            print "isGroupLayer - " + str(layer.isGroupLayer)
    del mxd
JakeSkinner
Esri Esteemed Contributor
Here is an example on how to find out if a map layer is within a group layer:
import arcpy
from arcpy import env
from arcpy import mapping
env.workspace = r"C:\TEMP\PYTHON"
mxd = mapping.MapDocument(r"C:\TEMP\PYTHON\Airports.mxd")
dfs = mapping.ListDataFrames(mxd)
for df in dfs:
    lyrs = mapping.ListLayers(mxd, "", df)
    for lyr in lyrs:
        if lyr.isGroupLayer == True:
            print lyr.name
del mxd
HenkZwols
Thanks, that works. I suggest to rename this property to isInsideGroupLayer :confused:
Is there a way to findout what the name of the grouplayer is?
Greetings, Henk
JakeSkinner
The below code will probably give you more of what you are looking for.  It will print the Group Layer and the map layer.
Ex:  Townships of PA\Delaware County
'Townships of PA' is the Group Layer, and 'Delaware County' is the Map Layer.
import arcpy
list = []
for df in dfs:
    for lyr in lyrs:
        list.append(lyr.longName)
for s in list:
    if "\\" in s:
        print s
del mxd
HenkZwols
Thanks for your support
Greetings, Henk
