InsertCursor throwing "error return without exception set"
2996
10-20-2021 06:09 AM
JD_1609
I'm trying write data to an Enterprise geodatabase but it still throws error return without exception set (for clarification - error throws row cursor.insertRow(data).
I have method:
def __insertDataInternal(self, table, cols, data):
    with arcpy.da.InsertCursor(table, cols) as cursor:
which I'm using for write to local gdb and remote (sde). For local gdb is everything alright and data are inserted. But when I use this method for write to Oracle it throws error.
Code for calling to write to EGDB looks this:
db = r"C:\Temp\file.sde"
edit = arcpy.da.Editor(db) edit.startEditing(False, True) edit.startOperation() self.__insertDataInternal(table_path, cols, data) edit.stopOperation() edit.stopEditing(True)
I'm using versioned DB (Oracle) and the connection is set looking to version I need. All input data and cols are correct.
When I was googling so I found only solutions with errors from startOperation() or startEditing() but nowhere is error straight from insertRow().
by Anonymous User
Not applicable
It's saying there is an unhandled error occurring. Wrap the process in a try/ except block to capture it and see what it is.
try:
except Exception as ex:
    print(f'Failed: {ex}')
JD_1609
yes, I have it in try/except block and from that is "error return without exception set"... 😕
by Anonymous User
Not applicable
Paste the full error message/code.
JD_1609
That's the **bleep**... This - "error return without exception set" - is full message what I get... NOTHING else 😄
by Anonymous User
Not applicable
Is the length of your fields in your 'data' longer than the length allowed in any of the fields?
add a print statement to your insert cursor and watch what values are being inserted and if it fails on one.
