in pyt (Python Toolbox) why can't I make the parameter Optional?
6915
5
09-30-2014 01:13 AM
MartinHvidberg
Dear Community
When defining parameters in a .pyt (Python toolbox) I would like to make one of the parameters optional - I think.
It's a boolean parameter, allowing the user to specify weather the tool is allowed to overwrite certain values.
I have made it default to False, and that would be the correct setting in 9 of 10 cases, so I would prefer if the tool would be able to just go with this default value. Unfortunately, when run, the tool insist that I toggle the boolean, before it will remove the little green dot. If I run the tool with the default values untouched, it gives me an error-box saying: "ERROR 000735: Overwrite Existing OBJNAM and NOBJNM: Value is required"
I have tried to change the parameter from parameterType="Required", to parameterType="Optional", but it seems to have no effect on the tool behaviour.
I have decided to paste the entire code here, it's still 90% cut-and-paste from ArcGIS Help (10.2, 10.2.1, and 10.2.2) , ArcGIS Help (10.2, 10.2.1, and 10.2.2) , and others but I guess the error is in a combination of things, and not the isolated line.
I have marked the parameter (line 81), that I try to change to make a difference.
# Name:       GNDBtoolbox.pyt
# Purpose:    A python-toolbox to work with the "Greenlandic Names Data Base" (GNDB) and NIS.
# Author:     Martin Hvidberg
# e-mail:     [email protected], [email protected]
# Created:    2014-09-16
# Copyright:  CopyLeft
# ArcGIS ver: 10.2.0
# Python ver: 2.7.3
import arcpy
class Toolbox(object):
    def __init__(self):
        """Define the toolbox (the name of the toolbox is the name of the .pyt file)."""
        self.label = "The_GNDB_Toolbox"
        self.alias = "Toolbox to work with GNDB and NIS"
        self.description = "This is the description of the toolbox..."
        # List of tool classes associated with this toolbox
        self.tools = [GNDBruninTOC]
class GNDBruninTOC(object):
    GNDB update NIS - assuming feature classes all ready opened in TOC
    Created on 27 Sep 2011
    @author: [email protected] / [email protected]
    def __init__(self):
        """Define the tool (tool name is the name of the class)."""
        self.label = "GNDB_update_NIS_run_in_TOC"
        self.description = "This tool will update the selected NIS FC, which must be in the TOC"
        self.canRunInBackground = True # True = Obey "Background Processing setting" in the Geoprocessing Options dialog.
    def getParameterInfo(self):
        """Define parameter definitions"""
        # 0. The Feature layer to receive GNDB names
        param0 = arcpy.Parameter(
            displayName="Input Features",
            name="in_features",
            datatype="GPFeatureLayer",
            direction="Input")
        # 1. The point feature class holding the GNDB
        param1 = arcpy.Parameter(
            displayName="GNDB points",
            name="GNDB",
            direction="Input")
        param1.value = "NamesP"
        # 2. The Mode
        param2 = arcpy.Parameter(
            displayName="The Mode",
            name="Mode",
            datatype="GPString",
            direction="Input")
        param2.filter.type = "ValueList"
        param2.filter.list = ["Berit", "Test"]
        param2.value = param2.filter.list[0]
        # 3. Overwrite
        param3 = arcpy.Parameter(
            displayName="Overwrite Existing OBJNAM and NOBJNM",
            name="Overwrite",
            datatype="GPBoolean",
            parameterType="Optional",   # <------ This seems to have no effect ?
            direction="Input")
        param3.value = "False"
        params = [param0, param1, param2, param3]
        return params
    def isLicensed(self):
        """Set whether tool is licensed to execute."""
        return True
    def updateParameters(self, parameters):
        """Modify the values and properties of parameters before internal
        validation is performed.  This method is called whenever a parameter
        has been changed."""
        return
    def updateMessages(self, parameters):
        """Modify the messages created by internal validation for each tool
        parameter.  This method is called after internal validation."""
        return
    def execute(self, parameters, messages):
        """The source code of the tool."""
        # put processing here ...
        return
TimothyHales
Esri Notable Contributor
Martin,
I created a new pyt with the code provided, and the parameter shows optional for me:
Have you refreshed the toolbox since you updated the code? Could you try copying it into a new pyt?
Timothy
TomGeo
Hi Martin,
I checked some of my code in a Python toolbox and was wondering if you can solve the problem by simple omitting the line param3.value = "False". The standard behaviour as far as I can see is anyway to have the checkbox unchecked. When I force my optional parameters to be true by setting param3.value = "True" then it works without any problems.
Hope it helps!
Otherwise... give me a call 😉
Cheers, Thomas
- We are living in the 21st century.
GIS moved on and nobody needs a format consisting out of at least three files! No, nobody needs shapefiles, not even for the sake of an exchange format. Folks, use GeoPackage to exchange data with other GIS!
MartinHvidberg
Hi Thomas - nice to hear from you...
Unfortunately that line is the solution to an earlier problem Re: in a pyt (python toolbox): How do I make a boolean parameter default False??? so I would like to keep it.
/ Martin
TimothyHales
Martin,
Timothy
MartinHvidberg
Thanks for your reply.
I restarted ArcMap, and now everything works exactely as expected 🙂 ???
/ Martin
MartinHvidberg
for the record: I had used 'refresh toolbox' many times during the edits, so that was not the problem.
/ M
