Importing and running GP service works in Python window and Notebook but not Toolboxes?
487
03-25-2025 08:11 AM
AlfredBaldenweck
MVP Frequent Contributor
Pro 3.3
I have a GP service that I'm trying to run from a toolbox.
The specific tool takes a layer object as its only input parameter.
I can run the following code just fine in the Python Window and in a Notebook, and it works great.
However, in a tool (ATBX, PYT), the code just skips past that line-- the entire thing takes like 2 seconds with no output instead of the 30+ it takes in a Notebook.
I can tell that it's feeding in correctly, since if I, for example, feed it a list instead of a layer, it throws an error because the parameter type is wrong.
Here is the code that I am using.
arcpy.ImportToolbox(r"toolboxURL;toolboxFolder")
aprx = arcpy.mp.ArcGISProject("CURRENT")
mp = aprx.activeMap
lay = mp.listLayers()[0]
arcpy.ToolBoxAlias.Tool(lay)
Does anyone have any idea of what's going on and how to fix this?
