ImportError: No module named win32con
15396
8
03-20-2018 06:36 AM
JaredPilbeam2
I updated from ArcMap 10.4 to 10.5 and now Pythonwin is not opening. Here is the full error message:
  File "<string>", line 1, in <module>
  File "pywin\framework\startup.py", line 49, in <module>
    __import__(moduleName)
  File "C:\Python27\ArcGIS10.4\Lib\site-packages\pythonwin\pywin\framework\intpyapp.py", line 3, in <module>
    import win32con
It's looks as though it is because it's still rooted in the ArcGIS 10.4 folder. What is the best way to fix this?
JimmyKroon
I had this same problem today after upgrading from 10.4 to 10.5. I'm not sure Dan understood that the error message occurs when opening PythonWin itself - probably caused by PythonWin looking for ArcGIS 10.4 components that are no longer installed.
I fixed this by reinstalling PythonWin from here. You most likely want the win32-py27 version.
Releases · mhammond/pywin32 · GitHub
DanPatterson_Retired
.....Python27\ArcGIS10.4\Lib\site-packages\pythonwin\pywin\framework\intpyapp.py",
What is running you access to pythonwin?  I just used to use pythonwin.exe in my shortcut
Also, I think it is win32com not n
JimmyKroon
JaredPilbeam2
Jimmy,
Thanks for the info. Did you install in your ArcGIS 10.5 folder?
I did download the win32-py27 version as ArcMap requires Python 2.7. It saved to my 10.5 folder: C:\Python27\ArcGIS10.5. I got this Setup message and then finished the install. I'm not sure what this message meant. I opened Pywin and tried a few of my scripts. There were errors for all of them. It won't even import the Arcpy module, or any module for that matter. It seems as though it doesn't know where to find them.
I uninstalled then reinstalled Pywin, but the same message appears. Have any idea what I'm doing wrong?
JaredPilbeam2
Update:
I uninstalled ArcMap 10.5.1 then reinstalled. Might not have been necessary but it made sure i started fresh. I also deleted any folders referring to older versions of ArcMap.
This is where I then installed the version of PythonWin you pointed out: C:\Python27\ArcGIS10.5\Lib\site-packages
The pywin32-223.win32-py2.7.exe version is compatible with Python IDLE 2.7.13, which is the version that is installed with ArcGIS 10.5.1. After the install the PythonWin application lives here: C:\Python27\ArcGIS10.5\Lib\site-packages\pythonwin\Pythonwin.exe
I think before I was simply not installing it in the correct location.
Jared... from my initial post
....Python27\ArcGIS10.4\Lib\site-packages\pythonwin\pywin\framework\intpyapp.py",  (note the path)
you will see where that intpyapp.py file should reside.
The only thing that changes per version is the drive  ie C and the arcmap version ArcGIS10.x
That is why your initial installation wasn't working
JaredPilbeam2
Thanks Dan,
I see what you mean now. To run the program, I was using a shortcut of the Pythonwin.exe out of the 10.4 folder, I believe. That's what I'm doing now out of the 10.5 folder.
In short, using a separate install of Python to run scripts that call the arcpy module will give you problems.
LauraTateosian_augori
I just installed ArcGIS Pro 3.2
When I installed PyWin32 through Pro's update package interface, I was getting this error when I opened PythonWin:
ModuleNotFoundError: No module named 'pywin. "scintilla'"
To fix it, I had to run pip install pywin32  (on the command line, specifying the full path of the pip.exe)
