I am working on a script in PyCharm. When I run my set up lines:
import arcpy, os
from arcpy import env
from arcpy.management import Delete, Rename, Copy, CreateFileGDB, CalculateGeometryAttributes
I get the following error:
ImportError: cannot import name CalculateGeometryAttributes
I need the CalculateGeometryAttributes tool in the last step of the script, and my code was working fine before I added it in. I was able to import and use Delete, Rename, Copy, and CreateFileGDB from the Management toolbox without issue.
I can't figure out what I'm doing wrong here and why this tool in particular is not able to import. Any help would be appreciated!
