IDLE Python error after up upgrade - subprocess didn't make connection
8544
03-21-2015 02:48 AM
timdunlevie
Hi all,
Yesterday running ArcGIS 10.2 I was running IDLE 2.7 shell perfectly !
I upgraded to ArcGIS 10.2.2 and now whenever I try and boot up IDLE I get this error:
IDLE's subprocess didn't make connection. Either IDLE can't start a subprocess or personal firewall software is blocking the connection.
Anyone experienced this before ???
Anyone have a solution?
I essentially can't run any python script.
I am running windows 7 service pack 1, 64 bit machine.
help ?
(edit - I have also uninstalled ArcGIS and reinstalled)
Thanks
MichaelAugust
DId you ever find a solution to this? After 10.3 I can't run IDLE either I get the same error, but it worked at 10.2...
timdunlevie
Hi Michael,
Yeah I got around the problem but running the Python 2.7.9 shell with “No Subprocess”.
To do this the target for the python.exe (under properties) is:
C:\Python27\ArcGIS10.2\pythonw.exe lib\idlelib\idle.py –n
Regards,
Tim
