I need help on the Update Cursor function
11625
42
08-23-2012 07:27 AM
OLANIYANOLAKUNLE
Im trying to update a field called "GENERATED" with an attribute called "GENERATED" every time i autogenerate a map, i constructed this script and it is not updating and i didnt see an error(s)
rows = arcpy.UpdateCursor("Parcels",'[OBJECTID] = "1"')
row = rows.next()
while row:
    row.setvalue(GENERATED, GENERATED)
    rows.updateRow(row)
    row = rows.next()
Please any suggestions. Im desperate. Thanks
ChristopherThompson
curtvprice;227108 wrote:
Why not get the date as a string and use the Calculate Field tool? This is easier and much faster than a cursor, even the newfangled arcpy.da flavor.
I've often wondered about this, even if you have a series of updates or calculations to make, seems you could easily make a list of those, and iterate through that list.  The advantages of a cursor are clear when you have to make decisions about how to handle a particulare feature or row on a case by case basis.  But even for simple mass updates like this, doesn't the Calc Field tool simply implement a cursor behind the scenes?  Why is that inherently faster? Is it because the cursor doesn't have to work through the interpreter?
OLANIYANOLAKUNLE
Thanks Curtis Price, but please how can i include the current time also. Thanks
curtvprice
The details are in the Python documentation.
http://docs.python.org/library/time.html
import datetime
now = datetime.datetime.now()
strNow = now.strftime("%d %b %Y %H:%M:%S")
curtvprice
I don't know whether Calculate Field uses cursors, but I do know that there are at least three kinds of cursors in the ArcGIS universe: 1. arcpy cursors, 2. ArcObjects cursors (accessed through .NET) and 3. (new at 10.1) arcpy.da cursors.
Calculate Field can do complex decision making with a code block, but can only write to one field. All I know is that CF is much faster and more convenient to code, so for me it's preferable if you only need to write to one field.
OLANIYANOLAKUNLE
curtvprice, i intend to include the time in a field called Time_Generated?
import datetime
Where do i add the field?
ChrisSnyder
Honored Contributor
Just to debate Curtis' statement about cursors vs. CalculateField...
In my experience (which may be outdated now), when using the "PYTHON*" option in the CalculateField tool, the performace of the CalculateField tool and the gp/arcpy.UpdateCursor are exactly the same. A post on this topic from four years ago: http://forums.esri.com/Thread.asp?c=93&f=1729&t=262236#806786. In my mind, complex conditional expressions are much easier to deal with in an update cursor, and I generally reserve the CalculateField tool for only very simple expressions.
I have found new arcpy.da cursors are significantly faster (for a number of reasons) and are much more akin to the performace and functionality of the ArcObjects cursors and more similar in performance to the "VB" option in the CalculateField tool.
curtvprice
Thanks Chris - I hope you meant "discuss" -- the "right" way to do something can include many factors, including whether you need to support multiple versions of ArcGIS, what is easiest for you to code/maintain, what you "like", etc....
This is helpful information. I hadn't done any testing and probably didn't notice because like you, I tend to use Calculate Field for simple expressions using VBScript (the default), which as you have said - is faster than python cursors. Great to hear that arcpy.da cursors are near the speed of ArcObjects cursors.
OLANIYANOLAKUNLE
Thanks curtvprice for the nugget of information, please can you help me with this
Please can you kindly help with this script also; i am trying to do a search through my attribute table, for a field called TDP_Status and if the attribute is GENERATED, I want the arcpy script to print TDP ALREADY GENERATED and stop the process else it should continue with the buffer analysis. This is my small script
generatedFieldName = "TDP_Status"
rows = arcpy.SearchCursor("Parcels", '"TDP_Status" = \'GENERATED\'')
for row in rows:
if row.TDP_Status = 'GENERATED'
else:
arcpy.Buffer_analysis ("Parcels", "ClipFeature", "12.5 meters", "FULL", "ROUND", "LIST")
Any suggestions?
ChrisSnyder
Honored Contributor
Since you are only quering records where  'TDP_Status" = 'GENERATED'' in your cursor, the else statment (the Buffer) will never fire off.
OLANIYANOLAKUNLE
So what do you suggest i do? Please
