I need help on the Update Cursor function
11628
42
08-23-2012 07:27 AM
OLANIYANOLAKUNLE
Im trying to update a field called "GENERATED" with an attribute called "GENERATED" every time i autogenerate a map, i constructed this script and it is not updating and i didnt see an error(s)
rows = arcpy.UpdateCursor("Parcels",'[OBJECTID] = "1"')
row = rows.next()
while row:
    row.setvalue(GENERATED, GENERATED)
    rows.updateRow(row)
    row = rows.next()
Please any suggestions. Im desperate. Thanks
MathewCoyle
Honored Contributor
As Chris mentioned earlier, you need to have setValue.
rows = arcpy.UpdateCursor("Parcels", "FID = 1")
for row in rows:
    row.setValue("GENERATED", "GENERATED")
    rows.updateRow(row)
ChrisSnyder
Honored Contributor
but can i start an edit session automatically with arcpy script
Actually, in v10.1, yes you can:
http://resources.arcgis.com/en/help/main/10.1/index.html#//018w00000005000000
Although I feel that extra complexity might not be what you actually want to do in this case...
OLANIYANOLAKUNLE
mzcoyle, please there is no difference between the code you pasted and the code i used? Please can you elaborate on the setvalue? Thanks
ChrisSnyder
Honored Contributor
setvalue vs setValue
Python is case sensitive... Meaning there is a difference between upper case (V) and lower case (v).
OLANIYANOLAKUNLE
I used your code
Code:
for row in rows:
    rows.updateRow(row)
i did not get any error but the record was not updated? Any suggestions
ChrisSnyder
Honored Contributor
Only use setValue() if the field name is a variable.
if your field IS NOT a variable:
for row in rows:
    row.GENERATED = "GENERATED"
    rows.updateRow(row)
if your field IS a variable:
myField = "GENERATED"
for row in rows:
    row.setValue(myField,"GENERATED")
    rows.updateRow(row)
OLANIYANOLAKUNLE
i want to generate a pdf output by using the arcpy.exporttopdf function, i want the final output to use this nomenclature for naming the pdf output (plot_no.pdf); the plot_no would be derived from an attribute value under the field named plot_no in the attribute table. Please do you have any suggestions. Thanks
OLANIYANOLAKUNLE
Thanks all i got it with all your suggestions, what happened was that i had to start an edit session to be able to see the changes. With this i have some layers from a parcel fabric within my dataframe which makes it difficult for me to use the edit = arcpy.da.Editor(workspace) it throws this error - can not open workspace. Any suggestion would go a long way. Thanks
OLANIYANOLAKUNLE
Im trying to automatically get the system time and date updated with the update cursor script, this is my script and the error
myField = "Date_Gener"
>>> rows = arcpy.UpdateCursor("Parcels")
>>> for row in rows:
...    row.setValue(myField,'Date (  )')
...    rows.updateRow(row)
Runtime error
  File "<string>", line 2, in <module>
  File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\arcobjects\arcobjects.py", line 1007, in setValue
    return convertArcObjectToPythonObject(self._arc_object.SetValue(*gp_fixargs(args)))
RuntimeError: ERROR 999999: Error executing function.
The value type is incompatible with the field type. [Date_Gener]
Any suggestions? Please....
curtvprice
>>> for row in rows:
Why not get the date as a string and use the Calculate Field tool? This is easier and much faster than a cursor, even the newfangled arcpy.da flavor.
import datetime
Today = str(datetime.date.today())
arcpy.CalculateField_management("Parcels","date_Gener","'" + Today + "'","PYTHON")
This will only calculate the value for selected rows of the layer "Parcels".
