How to switch the active map in ArcGIS Pro project
2877
01-05-2023 08:34 AM
BarakGarty
I have 2 Maps (tabs) in an active (loaded) project in the AcrGIS Pro SW.
Map1 is the active map. I am running a script via the python console  that intersect 2 layers (lyr1 and lyr2) that are in Map2 and output a new layer (lyr3);
The output of that intersect operation is added to the active Map (Map1) but I want it to be added to where the 2 layers that are being intersect are (i.e. Map2);
- I know that I can manually switch the active map by selecting it with the mouse prior to running my script. Don't want to do it this way....
- Is there a python method to force that switch? I tried using openView() but this is not the solution I am looking for as this opens another view of Map2 that already exists.
* this same question was asked in this forum last May but was not answered.
Thanks in advance.
2 Solutions
DanielMiranda2
When I ran into this issue, I set the environmental variable addOutputsToMap to false. This of course only works if you are running your code in Pro, which it sounds like you are.
arc.env.addOutputstoMap = False
That stops layers from being automatically added to maps. Then, if you store the result of your intersect in a variable, you can use addDataFromPath on the specific map you want to add the layer to.
Relevant links:
env—ArcGIS Pro | Documentation (search addOutputstoMap
Map—ArcGIS Pro | Documentation (search addDataFromPath)
BarakGarty
Excellent!
I used your solution and found it to work for my needs in this case.
Thank you.
DanielMiranda2
Relevant links:
BarakGarty
Excellent!
Thank you.
DougGreen
It sounds like you want to specifically check if a map is open as a View and then work with it if it is open and if it is not open, you want to open it and then specifically add layers to a certain map correct?
There's a post here where it indicates that there's not a way to tell if a map is open in a view and an ESRI employee suggests that it would be good to submit an idea that exposes that property of a map.
However, despite knowing whether or not the view is open, explicitly getting a reference to each map using the aprx object that you want to interact with is totally possible and might meet your need.
aprx = arcpy.mp.ArcGISProject("CURRENT")
map1 = aprx.listMaps("my first map")
if map1 == None:
    print("Could not find map: my first map")
    # end or raise error here
map2 = aprx.listMaps("my second map")
if map2 == None:
    print("Could not find map: my second map")
Each map object could then be used to add layers as you wish.
