how to split a polyline into equal segments with python
12766
07-03-2014 07:11 AM
ruiyang
I am trying to split a road (a line feature) into equal size segment. I know there is a way to do it in ArcGIS (editor-split), but this can not be coded with python script. Is there anyone can help me to code this? Or Any hint could be very helpful.
MathewCoyle
Honored Contributor
Here is something I wrote that will build points along the line that you can then feed to the split by point tool.
def points_along_line(line_lyr, pnt_layer, pnt_dist):
    line_lyr (feature layer) - Single part line
    pnt_layer (feature layer) - Path to point feature class
    pnt_dist (integer) - Interval distance in map units to add points
    search_cursor = arcpy.da.SearchCursor(line_lyr, 'SHAPE@')
    insert_cursor = arcpy.da.InsertCursor(pnt_layer, 'SHAPE@')
    for row in search_cursor:
        for dist in range(0, int(row[0].length), pnt_dist):
            point = row[0].positionAlongLine(dist).firstPoint
            insert_cursor.insertRow([point])
It was setup to work on an existing point feature class. You could just as easily add a few lines to create it on the fly.
    if not arcpy.Exists(pnt_layer):
        arcpy.CreateFeatureclass_management(
            os.path.dirname(pnt_layer), os.path.basename(pnt_layer), 'POINT')
    return pnt_layer
Then add the split line at point tool where you call the function.
points_along_line(line_features, point_features, pnt_dist)
arcpy.SplitLineAtPoint_management(line_features, point_features, out_feature_class)
MathewCoyle
Honored Contributor
    return pnt_layer
JoshuaBixby
MVP Esteemed Contributor
Coincidentally, this exact same topic came up in ArcPy Café the other week:  Split into equal length features.  A team member Dave (I don't know him other than his name is Dave) provided a fairly compact and elegant solution.
jaykapalczynski
Honored Contributor
All I am trying to do is highlight a line segment and have to user click somewhere on the line and split it into two segments....user define split.
EDIT:  Trying to do this in an ArcGIS online app or a written JavaScript app.
BlakeTerhune
jay kapalczynski
You should really post this question in the ArcGIS API for JavaScript​ area.
jaykapalczynski
Honored Contributor
Just realized that and just did that…thanks
Thanks
Jay
Jay Kapalczynski
GIS Coordinator - Virginia Department of Game & Inland Fisheries
(new address) 7870 Villa Park Drive Suite 400, Henrico VA 23228
Phone: 804.367.6796 | Fax: 804.367.2628
ü Please consider the environment before printing this email.
