tempId = Raster(dsm_file)*0 tempId = SRTran.GetId(tempId)
I am not sure what you are trying to do, but I don't think you can do it that way.You cannot have the same raster on both sides of a map algebra statement.Try making an intermediate raster, and using it on the left in line 1and on the right in line 2One of the dreary things about map algebra is that you end up with a lot of intermediate rasterswhich you have to (that is to say, really want to) clean up afterwards (or as you finish with each one).
Unless I am mistaking your workflow,You are starting with a raster (call it A)and want an output raster we will call Cand need an intermediate raster we will call Bso if you make B using B = Function(A),and make C using C = AnotherFunction(B)you want to know why making B from Aand then deleting B beforemaking C from Bdoes not work?
From what I understand, the intermediate rasters may still be referenced by later raster operations, even after you delete their files. It’s interesting that the workflow works when you delete them only after creating the final output. Thanks for sharing the example!
Signed in members can post, follow updates, and more. New here? Register a free account.
