how to make a tool box from python script
1241
04-22-2024 02:59 PM
MahdiMohammed
I have this code:
import arcpy
# Get the active map in the current project
active_map = arcpy.mp.ArcGISProject("CURRENT").activeMap
# Get the currently selected layer in tcrhe Contents pane
current_layer = active_map.listLayers()[0]  # Assumes the first layer; adjust as needed
# Define the desired new name
new_layer_name = "HZ004"
# Check if the layer was found
if current_layer:
    # Update the layer's name in the Contents pane
    current_layer.name = new_layer_name
    # Select and unselect the layer to trigger a refresh in the TOC
    current_layer.visible = False
    current_layer.visible = True
    print(f"The layer name in the Contents pane has been successfully changed to {new_layer_name}.")
else:
    print(f"No layer found in the project.")
# begin of required paramters
# name of the Lot layer that will be sampled
Polygon_Layer = "HZ004"
# sampling percentage
Sampling_Percent = 0.04
# the cell width and height for fishnet
# determine the size of each cell
cellSizeWidth = '25'
cellSizeHeight = '25'
#task Id and Lot Parameter
taskId = "NPA_CL_SY01_001"
lotNum = "LOT01"
Fishnet_Layer = "Fishnet004"
labels = 'NO_LABELS'
# end of required paramters
#begin of optional parameter - no need to change
# Number of rows and columns for fishnet if we don't determin width and height of cell
numRows =  '0'
numColumns = '0'
# Create a point label feature class for the fishnet
#labels = 'NO_LABELS'
# name of fishnet layer
# Fishnet_Layer = "Fishnet004"
# end of optional parameter
import arcpy
# Get the current project
project = arcpy.mp.ArcGISProject("CURRENT")
# Get a list of all the layers in the project
layers = []
for map in project.listMaps():
  layers.extend(map.listLayers())
# Find the feature class you want to use as the clip feature
clip_feature = None
for layer in layers:
  if layer.isFeatureLayer:
      if layer.name == Polygon_Layer :
          clip_feature = layer
          break
extent = project.activeView.camera.getExtent()
# fishnet options and creation
# Set the latitude and longitude coordinates for fishnet
latitude = extent.XMin
longitude = extent.YMin
maxLongitude = extent.YMax
maxLatitude = extent.XMax
originCoordinate = "%f %f" % (latitude,longitude)
yAxisCoordinate = "%f %f" % (latitude,maxLongitude)
conrnerCoordinate = "%f %f" % (maxLatitude,maxLongitude)
arcpy.CreateFishnet_management(Fishnet_Layer, originCoordinate,yAxisCoordinate , cellSizeWidth, cellSizeHeight, numRows, numColumns, conrnerCoordinate, labels, '', 'POLYGON')
arcpy.management.DefineProjection(Fishnet_Layer, arcpy.SpatialReference(arcpy.mp.ArcGISProject("CURRENT").activeMap.spatialReference.name))
# end of fishnet creation
arcpy.management.SelectLayerByLocation(Fishnet_Layer, "INTERSECT", Polygon_Layer, None, "NEW_SELECTION", "NOT_INVERT")
arcpy.management.AddField(Fishnet_Layer, "Box_Number", "TEXT", None, None, 15, "Box_Number", "NULLABLE", "NON_REQUIRED", '')
arcpy.management.CalculateField(Fishnet_Layer, "Box_Number", "SequentialNumber()", "PYTHON3", """# Calculates a sequential number
# More calculator examples at esriurl.com/CalculatorExamples
rec=0
def SequentialNumber():
  global rec
  pStart = 1
  pInterval = 1
  if (rec == 0):
      rec = pStart
  else:
      rec = rec + pInterval
  return rec""", "TEXT", "NO_ENFORCE_DOMAINS")
# Get the full path of the clip feature
clip_feature_path = clip_feature.dataSource
# Set the output feature class
output_fc = "Sampling_Polygon"
# Perform the clip
arcpy.analysis.Clip(Fishnet_Layer, clip_feature_path, output_fc)
import arcpy
import random
import string
# Set the workspace to the current workspace
arcpy.env.workspace = arcpy.mp.ArcGISProject("CURRENT").defaultGeodatabase
# Generate a random domain name starting with "Random_Status"
domain_name = "Sampling_Status_" + ''.join(random.choices(string.ascii_uppercase + string.digits, k=3))
# Check if the domain already exists and delete it if it does
if arcpy.Exists(domain_name):
 arcpy.management.DeleteDomain(arcpy.env.workspace, domain_name)
# Create the domain
arcpy.management.CreateDomain(arcpy.env.workspace, domain_name, "Sampling Domain Status", "TEXT", "CODED")
arcpy.management.AddCodedValueToDomain(arcpy.env.workspace, domain_name, "Random Pending", "Random Pending")
arcpy.management.AddCodedValueToDomain(arcpy.env.workspace, domain_name, "Random Passed", "Random Passed")
arcpy.management.AddCodedValueToDomain(arcpy.env.workspace, domain_name, "Random Failed", "Random Failed")
arcpy.management.AddCodedValueToDomain(arcpy.env.workspace, domain_name, "Random Replaced", "Random Replaced")
arcpy.management.AddCodedValueToDomain(arcpy.env.workspace, domain_name, "Targeted Pending", "Targeted Pending")
arcpy.management.AddCodedValueToDomain(arcpy.env.workspace, domain_name, "Targeted Passed", "Targeted Passed")
arcpy.management.AddCodedValueToDomain(arcpy.env.workspace, domain_name, "Targeted Failed", "Targeted Failed")
# Get the "Sampling_Polygon" feature layer
sampling_polygon_layer = arcpy.mp.ArcGISProject("CURRENT").listMaps()[0].listLayers("Sampling_Polygon")[0]
# Check if the "Random_Status" field already exists and delete it if it does
if "Sampling_Status" in [f.name for f in arcpy.ListFields(sampling_polygon_layer)]:
 arcpy.management.DeleteField(sampling_polygon_layer, "Sampling_Status")
# Add the "Random_Status" field to the layer
arcpy.management.AddField(sampling_polygon_layer, "Sampling_Status", "TEXT", field_length=50)
# Assign the random domain to the "Random_Status" field in the layer
arcpy.management.AssignDomainToField(sampling_polygon_layer, "Sampling_Status", domain_name)
arcpy.management.AddField("Sampling_Polygon", "X", "TEXT", None, None, None, "X", "NULLABLE", "NON_REQUIRED", '')
arcpy.management.AddField("Sampling_Polygon", "Y", "TEXT", None, None, None, "Y", "NULLABLE", "NON_REQUIRED", '')
arcpy.management.CalculateGeometryAttributes("Sampling_Polygon", "X INSIDE_X;Y INSIDE_Y", '', '', None, "SAME_AS_INPUT")
arcpy.management.AddField("Sampling_Polygon", "TaskID", "TEXT", None, None, None, "TaskID", "NULLABLE", "NON_REQUIRED", '')
# Use an update cursor to update the field
with arcpy.da.UpdateCursor("Sampling_Polygon", "TaskID") as cursor:
    for row in cursor:
        row[0] = taskId
        cursor.updateRow(row)
# Clean up the cursor
del cursor
arcpy.management.AddField("Sampling_Polygon", "Lot_Number", "TEXT", None, None, None, "Lot_Number", "NULLABLE", "NON_REQUIRED", '')
with arcpy.da.UpdateCursor("Sampling_Polygon", "Lot_Number") as cursor:
    for row in cursor:
        row[0] = lotNum
del cursor
import arcpy
import random
# Define the feature layer and field names
feature_layer = "Sampling_Polygon"
area_field = "SHAPE@AREA"
oid_field = arcpy.Describe(feature_layer).OIDFieldName
# Calculate the area threshold for selecting records
total_area = sum(row[0] for row in arcpy.da.SearchCursor(feature_layer, area_field))
area_threshold = total_area * Sampling_Percent  # Sampling_Percent% of the total area
# Select a random box to start with
selected_boxes = []
selected_area = 0
with arcpy.da.SearchCursor(feature_layer, [area_field, oid_field, "SHAPE@"]) as cursor:
  row = random.choice([row for row in cursor])
  selected_boxes.append((row[1], row[2]))
  selected_area += row[0]
# Determine the minimum distance between selected boxes
min_distance = max([box[1].length / 100 for box in selected_boxes])
# Exclude boxes that are within the minimum distance from the selected boxes
excluded_boxes = set()
while selected_area < area_threshold:
  # Get the distance between the selected boxes and all other boxes
  distances = {}
  with arcpy.da.SearchCursor(feature_layer, [oid_field, "SHAPE@"]) as cursor:
      for row in cursor:
          if row[0] not in excluded_boxes:
              distance = min([box[1].distanceTo(row[1]) for box in selected_boxes])
              distances[row[0]] = distance
  # Select the box with the maximum distance from the selected boxes
  if not distances:
      break
  max_distance_oid = max(distances, key=distances.get)
  if distances[max_distance_oid] >= min_distance:
      excluded_boxes.add(max_distance_oid)
      with arcpy.da.SearchCursor(feature_layer, [area_field, oid_field, "SHAPE@"], "{0} = {1}".format(oid_field, max_distance_oid)) as cursor:
          row = next(cursor)
      # Update the minimum distance between selected boxes
  else:
      # If no box can be selected, reduce the min_distance and try again
      min_distance *= 0.9
# Select the randomly selected boxes by their ObjectIDs
selected_oids = [box[0] for box in selected_boxes]
where_clause = "{0} IN ({1})".format(oid_field, ','.join(str(oid) for oid in selected_oids))
arcpy.SelectLayerByAttribute_management(feature_layer, "NEW_SELECTION", where_clause)
arcpy.management.CalculateField("Sampling_Polygon", "Sampling_Status", "'Random Pending'", "PYTHON3", "", "TEXT", "NO_ENFORCE_DOMAINS")
# Delete the "Fishnet_Sampling_Polygon" layer if it exists
if arcpy.Exists(Fishnet_Layer):
 arcpy.management.Delete(Fishnet_Layer)
# Delete the "Exported_Polygon" layer if it exists
if arcpy.Exists(Polygon_Layer 😞
 arcpy.management.Delete(Polygon_Layer )
import arcpy
# Get the currently selected layer in the Contents pane
# Check if a layer is selected
if current_layer:
    # Get the layer name
    polygon_layer_name = current_layer.name
    # Set the output point feature class name
    output_points_fc = f"{polygon_layer_name}_Vertices_Points"
    # Use the Feature Vertices to Points tool
    arcpy.management.FeatureVerticesToPoints(polygon_layer_name, output_points_fc, "ALL")
    print(f"Points have been created from the vertices of the {polygon_layer_name} layer.")
else:
    print("No layer found in the project.")
and its working when I run it in python window.
can any one help me to craete a tool box based on this code
DanPatterson
MVP Esteemed Contributor
Code formatting ... the Community Version - Esri Community
would help people who wish to comment so they can refer to line numbers.
A quick tour of creating tools with Python—ArcGIS Pro | Documentation
will allow you to decide which type of toolbox you want to make
... sort of retired...
TonyAlmeida
MVP Regular Contributor
Are you wanting the scrip to just run or are you wanting the ability to have drop downs that people can select from?
