Table Frames in ArcGIS Pro layout
1650
04-18-2024 10:39 PM
AnsgarG
I'm trying to create a new Table Frame or update the existing one. For the caseof creating a Table Frame using CIM the project immideatly shuts down. I tried the following code:
p = arcpy.mp.ArcGISProject("current")
lyt = p.listLayouts("Layout")[0]
lyt_cim = lyt.getDefinition("V3")
tf = arcpy.cim.CreateCIMObjectFromClassName("CIMTableFrame", "V3")
tf.anchor = "BottomRightCorner"
lyt_cim.elements.append(tf)
lyt.setDefinition(lyt_cim)
For Updating the existing Table Frame i tried to set the table as fields like following code:
m = p.listMaps("Map")[0]
table = m.addDataFromPath(r"path")
for elm in lyt_cim.elements:
    if elm == "Table Frame":
        elm.fields = table
Any ideas why this isnt working?
DanPatterson
MVP Esteemed Contributor
Was your example derived from
ArcGIS Pro 2.5 CIM Samples V1 - Overview
in the section for modifying tableframe objects? or was it examples in the cim folder, for example...
C:\...install path ...\Resources\ArcPy\arcpy\cim\CIMLayout.py
... sort of retired...
AnsgarG
I derived it, or rather i tried the same approach they have shown with their samples.
AnsgarG
Is it maybe because of missing table frame commands for the CIM Table Frame variable?
But which of these i have to set?
CIMTableFrame Class Properties
