How to install the conda package for "arcgis for python"
2808
07-18-2016 07:33 AM
xavierlhomme
Hi
I'm trying to install the conda package for  "arcgis for python"  with those command line :
  • conda install -c conda-forge ipywidgets
  • conda install -c esri arcgis=0.1
But I'm still having :
Could not connect to https://conda.anaconda.org/conda-forge/noarch/
Could not connect to https://conda.anaconda.org/esri/win-64/
I'm succeed to download those package manually.
arcgis-0.1-py35_0.tar.bz2
ipywidgets-5.1.5-py35_0.tar.bz2
How to install/deploy  them nanually ?
best regards
Xavier Lhomme
GIS Architect / ESIRI Expert
xavierlhomme
Hi
I tried : conda install --file C:\Users\...\Downloads\ipywidgets-5.1.5-py35_0.tar.bz2
but having "UnicodeDecodeError: 'charmap' codec can't decode byte ... "
Xavier Lhomme
ShaunWalbridge
Can you visit the URLs manually? https://conda.anaconda.org/esri/win-64/​ should resolve in most environments. Also, what version of Python are you installing into? Python 3.5?
DanPatterson_Retired
depending on your needs and whether you are going to use Pro... why not install ArcGIS PRO and install from there.  It will be python 3.4 but the differences are minimal until you get to 3.6 Anaconda, Spyder and ArcGIS PRO
