How to indentify duplicate or unique value in Pro RuntimeError: Error 999999
5426
11
02-23-2021 09:07 AM
JaredPilbeam2
I'm using the How to identify duplicate or unique values in Pro code provided by ERSI  verbatim, and I'm getting an error. I have a feature class table that I'm looking for duplicates in. The technical document doesn't say whether to use the field name or alias, so I tried both. When I run it with the field name the code throws an exception. I stopped the script and opened Pro. The field gets created in the table but it's all NULLs.
This is the line where the exception is being thrown:
i=row.getValue(field_in)
Exception/Error:
  Message=ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
  Source=\\GISFILE\GISSTAFF\Jared\Python Scripts\ArcGISPro\DuplicateFields.py
  StackTrace:
  File "\\GISFILE\GISSTAFF\Jared\Python Scripts\ArcGISPro\DuplicateFields.py", line 17, in <module>
When I run it with the alias it doesn't finish, or at least I've never let it because it's taking a remarkably long time. However, if I stop the script and open Pro to view the table, a lot of the 190K+ fields are written to. But, like I said it never finishes...
Code:
import arcpy
This script will count the number of occurences of a value in a field ("field_in") and write them to a
new field ("field_out")
arcpy.env.workspace = r"C:\Users\jpilbeam\Downloads\DuplicateTesting.gdb\DuplicateTesting.gdb" #path to GDB goes here
infeature = "backup_02232021" #name of feature class goes here
field_in = "name" #this is the alias of the field. Name: is the actual name
field_out = "COUNT_"+field_in
arcpy.AddField_management(infeature, field_out,"SHORT")
lista= []
cursor1=arcpy.SearchCursor(infeature)
for row in cursor1:
    i=row.getValue(field_in) #<-- where exception is thrown using field name in field_in variable
    lista.append(i)
del cursor1, row
cursor2=arcpy.UpdateCursor(infeature)
for row in cursor2:
    occ=lista.count(i)
    row.setValue(field_out, occ)
    cursor2.updateRow(row)
del cursor2, row
print("----done----")
EDIT: Using the alias, I let the code run for like 15-20 mins and it finished with no errors! So, I guess it just needs that long with all these records?
DanPatterson
MVP Esteemed Contributor
perhaps there are leading or trailing spaces in the field names if it was produced in Survey123.  That would be a fieldname killer for sure.
... sort of retired...
JaredPilbeam2
Thanks for the reply about using numpy. I'm not that advanced yet, but i'll earmark the post.
