How to find the 2 or 3 nearest points
2141
04-19-2024 10:59 AM
SanchezNuñez
Good afternoon,
I am looking for a way to find the 2 or the nearest facilities from a point.
Is there a way to get more than one candidate using arcpy.analysis.Near?
Regards
3 Solutions
BlakeTerhune
Try Generate Near Table and specify the closest_count parameter as 2
Dale_Honeycutt
Check outGenerate origin destination links
It may fit your use case - it creates a ‘spider diagram’
SanchezNuñez
Thank you @BlakeTerhune   and @Dale_Honeycutt  for your answers.
Tom_Laue
Never tried to do this but thinking in my head...
Using a Loop...
  • Do a near analysis and get the OID of the nearest feature.
  • Then make a feature layer but def query to display all features EXCEPT the OID returned
  • Run Near Analysis again against the queried feature layer to get the 2nd closest feature
BlakeTerhune
Dale_Honeycutt
SanchezNuñez
