how to extent of the map view in arcgis pro to the same size as polygon's feature class
2735
02-01-2021 02:03 AM
cinnaaaoo
How to extent of the map view as an image format in arcgis pro to the same size as polygon's feature class?
From converting this code
import arcpy, os
aprx = arcpy.mp.ArcGISProject("CURRENT")
mv = aprx.activeView
# Change the extent of the map view
ext = mv.camera.getExtent()
ext.XMin = ext.XMin
ext.YMin = ext.YMin
ext.XMax = ext.XMax
ext.YMax = ext.YMax
mv.camera.setExtent(ext)
Output_File = os.path.join(arcpy.env.scratchFolder, 'ActiveMapView3.png')
mv.exportToPNG(Output_File, width=1000, height=1000)
by Anonymous User
Not applicable
I think you can just use the MapFrame class to do this.
import arcpy
aprx = arcpy.mp.ArcGISProject(r"C:\Projects\YosemiteNP\Yosemite.aprx")
m = aprx.listMaps("Yose*")[0]
lyr = m.listLayers("Ranger Stations")[0]
lyt = aprx.listLayouts("Main Attr*")[0]
mf = lyt.listElements("mapframe_element", "Yosemite National Park")[0]
mf.camera.setExtent(mf.getLayerExtent(lyr, False, True))
aprx.exportToPNG(out_png, {resolution}, {world_file}, {color_mode}, {embed_color_profile})
del aprx
cinnaaaoo
I don't understand the coding of these 3 lines.
by Anonymous User
Not applicable
Those are from the example in the Docs.
lyr = m.listLayers("Ranger Stations")[0]  < replace with the name of the layer in your project that you want to get the extent from
lyt = aprx.listLayouts("Main Attr*")[0]  < replace with your layout name in your project
mf = lyt.listElements("mapframe_element", "Yosemite National Park")[0]  < replace 'Yosemite National Park' with your element name from your layout
Take a read of the Discussion in the docs.  It explains the Layout and ListElements methods.  MapFrame
