How to duplicate privileges from one SDE feature class to another with arcpy
5421
9
08-04-2014 06:11 AM
StefanOffermann
Is there a simple way to duplicate privileges from a SDE feature class to another one? The szenario is a nightly update process which builds an updated featureclass FC_new, deletes FC and renames FC_new to FC. Before deleting FC, the privileges for different SDE roles/users should be duplicated from FC to FC_new. Otherwise, they are lost.
If there are any database-related solutions, they are also welcome 🙂 I am using SQL Server and ArcSDE 10.2.2.
Tags (3)
JakeSkinner
Esri Esteemed Contributor
Hi Stefan,
You can include the Change Privileges function in your script.
JakeSkinner
Hi Stefan,
StefanOffermann
Hi Jake, thanks for this function, I can use it to write the privileges. But how can I read the existing privileges from the existing feature class? I havent found a function for that. I hoped the Describe-function can help me, but I could not find a Describe object containing the privileges of SDE tables / feature classes.
JakeSkinner
You can use the ArcSDESQLExecute function to execute the below SQL query to find the privileges for each user:
select permission_name, pr.name
from sys.database_permissions pe
join sys.database_principals pr on pe.grantee_principal_id = pr.principal_id
where pe.class = 1
    and pe.major_id = object_id('<owner>.<feature class name')
    and pe.minor_id = 0;
You will want to replace '<owner>.<feature class name>'.
Here is an example:
import arcpy
sde_conn = arcpy.ArcSDESQLExecute(r"Database Connections\[email protected]")
sql_statement = "select permission_name, pr.name from sys.database_permissions pe join sys.database_principals pr on pe.grantee_principal_id = pr.principal_id where pe.class = 1 and pe.major_id = object_id('vector.AIRPORTS') and pe.minor_id = 0;"
sde_return = sde_conn.execute(sql_statement)
for row in sde_return:
    print "User:  " + row[1] + "\t Privilege:  " + row[0]
StefanOffermann
Thanks for the code! I will try it. Although it would be quite nice if the geodatabase administration toolbox would also contain a GP tool to read privileges from a dataset, accordingly to Change Privileges tool.
JakeSkinner
Any enhancements you would like to see, you can post the idea on ESRI's ArcGIS Ideas page.
Polesig
I Tried your requests, but with no success...
On SQL Server requests written in the article https://sqlserverguides.com/sql-server-user-permissions/ worked for me.
StefanOffermann
My solution for our customer is to administer the privileges in a CSV-file. When updating the feature classes, the privileges a read from the file (not from the existing feature classes) and set via Change Privilege using a python script.
AndyOmmen
I think the easiest way would be to place the updated FC into a feature dataset where the user/role privileges are constant and apply to all FC's it contains. If using a feature dataset isn't possible then I would look into the Change Privilege GP tool. In this GP tool you can configure the privileges you want to assign to the user/roles on the new FC. Since its a GP tool you can run it in batch if there are multiple user/roles you need to configure. Scripting this in ArcPy would be an option as well.
StefanOffermann
Good hint to use feature datasets! Unfortunately, feature datasets are not used in our case.
