__author__ = "John K. Tran, Tristan Forward"
__contact__ = "jtran20@masonlive.gmu.edu, http://gis.stackexchange.com/users/6996/tristan-forward"
__version__ = "2.0"
__created__ = "7/3/15"
__credits__ = "http://gis.stackexchange.com/questions/124198/optimizing-arcpy-code-to-cut-polygon"
Cut polygons by polylines, splitting each polygon into slices.
:param to_cut: The polygon to cut.
:param cutter: The polylines that will each polygon.
:param out_fc: The output with the split geometry added to it.
import os
import sys
import arcpy
arcpy.SetProgressor("default", "Firing up script...")
to_cut = arcpy.GetParameterAsText(0)
cutter = arcpy.GetParameterAsText(1)
out_fc = arcpy.GetParameterAsText(2)
spatialref = arcpy.Describe(to_cut).spatialReference
polygons = []
lines = []
slices = []
gcount = 0
pcount = 0
with arcpy.da.SearchCursor(to_cut, ["SHAPE@", "OID@"]) as pcursor:
for prow in pcursor:
arcpy.SetProgressorLabel("Generating slices: {0} rows complete".format(str(pcount)))
polygon = prow[0]
polyid = prow[1]
polygons.append((polygon, polyid))
pcount += 1
del pcursor
lcount= 0
with arcpy.da.SearchCursor(cutter, ["SHAPE@", "OID@"]) as lcursor:
for lrow in lcursor:
line = lrow[0]
lineid = lrow[1]
lines.append((line, lineid))
lcount += 1
del lcursor
def cut_geometry():
global polygons
global lines
global slices
global gcount
for eachpoly, eachpolyid in polygons:
iscut = False
for eachline, eachlineid in lines:
if eachline.crosses(eachpoly):
try:
slice1, slice2 = eachpoly.cut(eachline)
polygons.insert(0, (slice1, eachpolyid))
polygons.insert(0, (slice2, eachpolyid))
iscut = True
except RuntimeError:
continue
if iscut == False:
slices.append((eachpoly, eachpolyid))
gcount += 1
if gcount % 10 == 0:
arcpy.SetProgressorLabel("Cutting polygons: {0} rows complete".format(str(gcount)))
polygons.remove((eachpoly, eachpolyid))
while polygons:
cut_geometry()
arcpy.SetProgressorLabel("Creating output feature class")
arcpy.CreateFeatureclass_management(os.path.dirname(out_fc), os.path.basename(out_fc), "POLYGON",
spatial_reference = spatialref)
arcpy.AddField_management(out_fc, "SOURCE_OID", "LONG")
scount = 0
with arcpy.da.InsertCursor(out_fc, ["SHAPE@", "SOURCE_OID"]) as icursor:
for eachslice in slices:
if scount % 10 == 0:
arcpy.SetProgressorLabel("Inserting slices: {0} rows complete".format(str(scount)))
icursor.insertRow(eachslice)
scount += 1
del icursor
arcpy.SetProgressorLabel("Deleting duplicate slices")
shapefieldname = arcpy.Describe(out_fc).shapeFieldName
arcpy.DeleteIdentical_management(out_fc, [shapefieldname, "SOURCE_OID"])
arcpy.ResetProgressor()
