How to calculate multiple equations (a+bX+cY+dZ), where (a, b, and c) are regression coeficients and (X, Y and Z) are rasters, using Pyton?
16905
35
09-03-2018 01:23 PM
LuizVianna
I need to run 252 equations to calculate freeze probability using lat, lon, and altitude as raster inputs, multiplied by a, b, c and d regression coeficients. The equations are in format a+b*lat+c*lon+d*alt.
The equations are in an Excel spreedsheet (attached) and I need to write them in a python script. The lat, lon and lat raster datasets are in the same folder and the output tif files have a standardized name (also in the Excel file).
Thank you!
LuizVianna
dir(arcpy.da)
['Describe', 'Domain', 'Editor', 'ExtendTable', 'FeatureClassToNumPyArray', 'InsertCursor', 'ListDomains', 'ListFieldConflictFilters', 'ListReplicas', 'ListSubtypes', 'ListVersions', 'NumPyArrayToFeatureClass', 'NumPyArrayToTable', 'Replica', 'SearchCursor', 'TableToNumPyArray', 'UpdateCursor', 'Version', 'Walk', '__all__', '__builtins__', '__cached__', '__doc__', '__file__', '__loader__', '__name__', '__package__', '__spec__', '_internal_eq', '_internal_sd', '_internal_vb']
DanPatterson_Retired
good!
That leave your file location, and source
what is the actual path to your geodatabase table
LuizVianna
I'd re-installed the ArcGis Pro 2.1.3 and the geodatabase  path is "D:\Vianna\Dados\Raster\Clima\Raster_Clima.gdb". It still crashing whe running: arr = arcpy.da.TableToNumPyArray(tbl, "*").
I also tried to export the table as .txt to D:\Temp and used:
tbl = r"D:\Temp\TB_EQUAC_ETP.txt"
This also crashes python.
Do you have null values in your records?
try adding … skip_nulls=True
TableToNumPyArray—Data Access module | ArcGIS Desktop
arr = arcpy.da.TableToNumPyArray(tbl, "*", skip_nulls=True)
LuizVianna
The same problem....
With "*" and with:
import numpy as np
import arcpy
arcpy.CheckOutExtension("spatial")
lat = np.arange(-29.373511, -25.928348, 0.000871310821466946, 'float')
lon = np.arange(-53.915588, -48.273851, 0.000871310821466947, 'float')
lon, lat = np.meshgrid(lon, lat)
alt = r"D:\Vianna\Dados\Raster\Topografia\mde_sc_90.tif"
tbl = r"D:\Vianna\Dados\Raster\Clima\Raster_Clima.gdb\TB_EQUAC_ETP"
fields=['SG_PREFIX','SG_SUFIX','SG_PERIO','SG_FORMA','VL_A','VL_B','VL_C','VL_D']
arr = arcpy.da.TableToNumPyArray(tbl, fields, skip_nulls=True)
Well nothing I have proposed has helped so I would suggest you contact Tech support
Good luck
LuizVianna
Thank you, Dan!
Unfortunatly the Tech Support could not help me.
Congratulations for your blog!
Best regards!
HåkonDreyer
Hi, Luiz
guess you should have a look at your gdb. Looks like all text fields in the tables are defined with a width of 2147483647.
Table properties dialog
When converting to a numpy array all string fields will be converted to fields of the same width, and my guess is that numpy doesn't cope with eight <u2147483647 columns in the array.
Tested, and after moving your table to a new table with more moderate field widths the function works ok.
strange, since the same data yielded …. '<U255' …. in the array for numpy 1.14.3 and  numpy 1.15.1 and Pro from ver. 2.1 to 2.2.2
HåkonDreyer
Is that what you got from converting the xlsx? I just looked at the gdb file he posted here.
