How to access map service layer in Python toolbox?
3943
06-02-2014 12:40 AM
RamiGhaly1
Hello,
I have a URL of a map service layer. How I can access this layer URL from python toolbox. (i.e create featureset from the layer URL).
Is it possible ?
Thanks and Regards.
AdamCox1
Hi Rami, I believe this previous question is very close to yours and you should be able to find the answer here: http://forums.arcgis.com/threads/8414-ArcGIS-10-user-python-arcpy-to-add-a-WMS-Service?p=391096#post...
RamiGhali2
I got this snippet from a friend.
I didn't try it.
import arcpy
# Modify the following variables:
# URL to your service, where clause, fields and token if applicable
baseURL= "http://sampleserver6.arcgisonline.com/arcgis/rest/services/PoolPermits/FeatureServer/1/query"
where = '1=1'
fields ='apn, address, pool_permit'
token = ''
#The above variables construct the query
query = "?where={}&outFields={}&returnGeometry=true&f=json&token={}".format(where, fields, token)
# See http://services1.arcgis.com/help/index.html?fsQuery.html for more info on FS-Query
fsURL = baseURL + query
fs = arcpy.FeatureSet()
  1. fs.load(fsURL)
arcpy.CopyFeatures_management(fs, r"c:\local\data.gdb\permits")
Regards,
Rami
