How do I exclude a dataset from the ListDatasets collection
2733
7
11-13-2012 05:00 AM
JoshCalhoun1
Hi Everyone,
I would like to run a gp tool on a list of data sets in sde. I would however, like to exclude one data set called countours from the process if possible. Does anyone here know how that might be done? Any help you all can give me will be greatly appreciated. Below is an example of the code I am using.
thanks,
Josh Calhoun
City of Chattanooga, GIS
import arcpy
from arcpy import env
import time
import os
arcpy.env.workspace = (r'Database Connections\GADMIN.sde')
fgdb = (r'E:\ChattGIS.gdb')
arcpy.Delete_management(fgdb)
arcpy.CreateFileGDB_management(r'E:', "ChattGIS.gdb")
for ds in arcpy.ListDatasets("*","Feature"):
    print ds
    outds = fgdb +"\\"+ ds[16:]
    arcpy.Copy_management(ds, outds)
outparcelLocator = fgdb +"\\"+ "Parcels"
outstreetLocator = fgdb +"\\"+ "Streets"
arcpy.Copy_management ('Database Connections\GADMIN.sde\GADMIN.Parcels', outparcelLocator)
arcpy.Copy_management ('Database Connections\GADMIN.sde\GADMIN.Streets', outparcelLocator)
RaphaelR
you could try this:
dsets = arcpy.ListDatasets("*","Feature")
for dataset in dsets:
    if "contour" in dataset:
        dsets.remove(dataset)
for ds in dsets:
    print ds
or a list comprehension:
dsets = [ds for ds in arcpy.ListDatasets("*","Feature") if "contour" not in ds]
JoshCalhoun1
Thanks for the suggestion but I was not able to get that to work. Instead of looping through each dataset I have it hardcoded for each data set. Unfortunately, I have run out of time for more troubleshooting. There are other projects I have to get started with.
Again Thanks for your help.
curtvprice
Unfortunately, I believe there were bugs in Rafael's code. These should work:
if "contour" in dsets:
  dsets.remove("contour")
The list comprehension version is kind of tricky to read, but it works too:
dsets = [ds for ds in arcpy.ListDatasets("*","Feature") if ds != "contour"]
RhettZufelt
MVP Notable Contributor
you could try this:
rsets = []
    if dataset != "contour":
        rsets.append(dataset)
for ds in rsets:
    print ds
Often trying to remove stuff from a set/list confuses things/orders.  I would probably just make a new list exculding what you don't want.
R_
RaphaelR
curious as to what´s bugged/why my code doesn´t work for you.
here´s what i get when i try in arcmap python window, seems to do ok:
>>> arcpy.env.workspace=("e:/test")
>>> ld = arcpy.ListDatasets("*","Raster")
>>> print ld
[u'myrasout.asc', u'ras_test2', u'ras_test22.asc', u'ras_test22.tif', u'ras_test2_2', u'ras_test3', u'ras_test3_3']
>>> for l in ld:
...     if "myrasout" in l:  # the one i´d like to filter out
...         ld.remove(l)
>>> print ld
[u'ras_test2', u'ras_test22.asc', u'ras_test22.tif', u'ras_test2_2', u'ras_test3', u'ras_test3_3']
and
ld1 = [ds for ds in arcpy.ListDatasets("*","Raster") if "myrasout" not in ds]
>>> print ld1
curtvprice
Rafael, your code has two problems I should have pointed out directly. These are both things that have tripped me up so I think they are worth sharing with the list.
1. You used of the "in" operator instead of "==" to compare strings. This could give you unexpected results because
"ras_test2" in l
would give a true for elements "ras_test2","ras_test22.asc", and "ras_test2_2".
2. This one has bit me before, and I missed it again in the code above. You should not modify a list while you are looping over it. Rhett probably has run into it, which is why he wisely makes a new list. (Note this is not an issue with the list comprehension because it is creating a new list, not modifying an existing one.)
An easy way to avoid the problem is to make a copy using list():
for l in list(ld):
    if l == "contour": ld.remove(l)
RaphaelR
What threw me of is your use of the "in" operator to compare strings. Your code would remove "contours","contour1", and "xcontour" because you are using "in" instead of "==" in your remove test
that´s true, sloppy on my part.
