Python error 00732
1683
11-13-2012 12:34 PM
TonyAlmeida
MVP Regular Contributor
I am trying to create a script that will provide a list of parcel within a certain distance. I am not sure if my expression is correct or not. The user would have to input an "ACCOUNT" and based on the input it would then select features within 600 ft and export those to a .dbf.
I am receiving the following error.
  File "C:\GIS\Python Scripts\MailingListings.py", line 61, in <module>
    arcpy.SelectLayerByLocation_management(tax_Layer, Overlap_Type, Output_Layer_Name, Search_Distance, "NEW_SELECTION")
  File "c:\program files (x86)\arcgis\desktop10.1\arcpy\arcpy\management.py", line 6585, in SelectLayerByLocation
    raise e
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000732: Selecting Features: Dataset 'R0392800000' does not exist or is not supported
Failed to execute (SelectLayerByLocation).
# Import arcpy module
import arcpy, string
# Allow processes to overwrite exisiting data
try:
    arcpy.Delete_management("C:\Temp\Listing.dbf")
except:
    pass
# Script arguments
TAX = arcpy.GetParameterAsText(0)
if TAX == '#' or not TAX:
    TAX = "O:\**\NotificationLots1152012.shp" # provide a default value if unspecified
SELECT_BY = arcpy.GetParameterAsText(1)
if SELECT_BY == '#' or not SELECT_BY:
    SELECT_BY = "\"ACCOUNT\" ='R0392800000'" # provide a default value if unspecified
Search_Distance = arcpy.GetParameterAsText(2)
if Search_Distance == '#' or not Search_Distance:
    Search_Distance = "600 Feet" # provide a default value if unspecified
Listing_dbf = arcpy.GetParameterAsText(3)
if Listing_dbf == '#' or not Listing_dbf:
    Listing_dbf = "C:\Temp\Listing.dbf" # provide a default value if unspecified
# Local variables:
tax_Layer = "TAX_1"
tax_Layer__3_ = "tax_Layer"
TaxParcels = "***Taxparcels"
Output_Layer_Name = SELECT_BY
Overlap_Type = "WITHIN_A_DISTANCE"
tax2_Layer = "tax_Layer"
whereClause = "ACCOUNT = " + str(SELECT_BY)
# Process: Make Feature Layer
arcpy.MakeFeatureLayer_management(TAX, tax_Layer, "", "", "FID FID VISIBLE NONE;Shape Shape VISIBLE NONE;DXF_TEXT DXF_TEXT VISIBLE NONE;ACCOUNT ACCOUNT VISIBLE NONE;OwnerName OwnerName VISIBLE NONE;Address Address VISIBLE NONE;City City VISIBLE NONE;State State VISIBLE NONE;ZipCode ZipCode VISIBLE NONE")
# Process: Make Feature Layer (2)
arcpy.MakeFeatureLayer_management(TaxParcels, tax2_Layer, "", "", "OBJECTID_1 OBJECTID_1 VISIBLE NONE;DXF_LAYER DXF_LAYER VISIBLE NONE;DXF_TEXT DXF_TEXT VISIBLE NONE;ACCOUNT ACCOUNT VISIBLE NONE;PIN PIN VISIBLE NONE;Shape Shape VISIBLE NONE;MinRights MinRights VISIBLE NONE;ACRES ACRES VISIBLE NONE;GlobalID GlobalID VISIBLE NONE;Shape.area Shape.area VISIBLE NONE;Shape.len Shape.len VISIBLE NONE")
# Process: Select Layer By Attribute
arcpy.SelectLayerByAttribute_management(tax2_Layer, "NEW_SELECTION", whereClause)
# Process: Select Layer By Location
# Process: Table Select
arcpy.TableSelect_analysis(tax_Layer__3_, Listing_dbf, "")
MathewCoyle
Honored Contributor
Your whereClause and Output_Layer_Name variables are a little mangled I think. If you are using the default SELECT_BY value.
Also you make selections on two different layers but only process one?
Also you should set up a workspace when working with layers.
Also you need to use raw strings if using single back slashes.
r"C:\Temp\Listing.dbf"
I would try writing some pseudo code of what your logic is then trying to rewrite it a little cleaner.
