How can i start the edit session for a layer warehoused in a geodatabase
9550
7
08-30-2012 10:00 PM
OLANIYANOLAKUNLE
This is the runtimeerror i get anytime i try to start an edit session for my layers warehoused in a geodatabase;
>>> edit = arcpy.da.Editor(mxd) Runtime error  Traceback (most recent call last):   File "<string>", line 1, in <module> RuntimeError: cannot open workspace >>>
Please how can i overwhelm this problem of mine? Thanks
BruceBacia
Here is an example:
gdb = r"C:\AllMyLayers.gdb" edit = arcpy.da.editor(gdb) edit.startEditing()      #you may want to adjust the parameters here.  You can read up on the documentation  ---whatever you want to do in your editing session  edit.stopEditing()     #again, you may want to adjust the save parameter.
BruceBacia
Instead of "mxd" , you want to put the full path of the geodatabase
BruceBacia
Here is an example:
OLANIYANOLAKUNLE
Thank you that trick did it...
OLANIYANOLAKUNLE
I want to pass the selection query below for a layer in my Geodatabase, how can i get i to be like the second query, the 1st 1 is not working;
arcpy.SelectLayerByAttribute_management("Parcels", "NEW_SELECTION", '"TDPDetails"' + "=" + "'" + selection + "'")
arcpy.SelectLayerByAttribute_management("Parcels", "NEW_SELECTION", [TDPDetails] + "=" + "'" + selection + "'")
How can i replace "TDPDetails" with [TDPDetails]?
Thanks
OLANIYANOLAKUNLE
How can i start the edit session for a layer warehoused in an ArcSDE geodatabase, I have moved my geodatabase to an ArcSDE geodatabase and ive been trying to start editing and it is giving me the error below; Please how do i go about this. Thanks
 gds = r"C:/Users/Administrator/AppData/Roaming/ESRI/Desktop10.1/ArcCatalog/GISSERVER_SQLEXPRESS.gds/KWAGISMAIN"
edit = arcpy.da.Editor(gds)
Runtime error
GreggPitts
Hi, I'm using Addin Assistant to make a button that will cycle edit sessions but I see that ArcPy wants the exact location of the GDB... Can I use a variable or function to pick up the layers that are visible so the user can cycle through those? They could be anything, anywhere... SDE, FGDB, PGDB etc...
Gregg
MartinHvidberg
What you want is likely an 'Editor' object
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
.. resources.arcgis.com/en/help/main/10.2/index.html#//00s300000008000000
/Martin
